Exclude conditions for Item Updated automation
Dmitry Alabyan
Greetings, community!
I have an automation that triggers upon "Work Item Updated".
Problem is, I need to specifically exclude any status changes to the issue from the trigger.
My first thought was to use {{#changelog.status}}{{fromString}}{{/}} for every status in the workflow as an IF condition - but this one, if I understand it correctly, will be pretty much blocking any executions of the rule, since there will be a changelog in the first place.
Any ideas how to make the rule work in WHEN work item updated EXCEPT for status change?
Bill Sheboy
June 30, 2025
Hi @Dmitry Alabyan
When a work item transitions, that is a different event type than for an update, and so your rule with the Work Item Updated trigger should not run.
Are you observing the rule run for a work item transition only, rather than bundled with other edits?
If so, please post images of your complete rule and the audit log details showing the rule execution for a work item transition.  Those will provide more context for the community to offer help.
Dmitry Alabyan
Problem is, Work Item Updated actually includes the status update transition.
It does not show it explicitly, the audit log just shows that the condition has been triggered. But we know through trial and error that the only thing changed was the status.Screenshot 2025-06-30 at 18.18.56.pngScreenshot 2025-06-30 at 18.12.53.png
Bill Sheboy
June 30, 2025
How are you updating the status of the work item such that it triggers the rule?
When I tested with a manual status transition (i.e., direct field edit or drag-and-drop on the board) the status transition does not trigger Work Item Updated...
However, with a drag-and-drop change on a non-empty board, the Rank field often updates, and that will trigger the rule.  This can be confirmed by writing the entire {{changelog}} smart value to the audit log.  And, that is a different event than the transition itself.
Dmitry Alabyan
hm. that's an interesting insight indeed.
so, what would be the correct expression to exclude ranking changes?
Bill Sheboy
July 6, 2025
Without knowing how the status change is happening, I am guessing what to suggest next.  That is why I asked that question earlier.
Again for checking a Rank change, please try writing the entire {{changelog}} smart value to the log and that will show what changes, and may be checked.  Although that may not help your case as the Rank can change for other reasons.
To specifically test for a transition, use that rule trigger.
If you are indeed observing the Work Item Updated trigger starting the rule when only the Status changes, I recommend working with your Jira Site Admin to contact Atlassian Support as this should not happen.
Dmitry Alabyan
@Bill Sheboy I can confirm your observation of "with a drag-and-drop change on a non-empty board, the Rank field often updates". So there are edgecases, where the Rank changes.
ANd that is what I would like to secure the automation against.
Any advice?
Bill Sheboy
July 13, 2025
Your original question seemed to be:
GIVEN a rule with a Work Item Updated trigger
WHEN a Work Item is transitioned to a new status
THEN I do not want the rule to process
I believe the possible cases are:
  • When only the status changes (e.g., by directly editing the Status from a single work item view), the rule should not trigger.  I have confirmed this with testing, and you may also do so for your own Jira site.
  • When the status change happens in a way where other fields change (e.g., drag-and-drop on the board), the changelog may be examined with a rule condition to not proceed if the Rank changed.  As the status cannot be changed with a simple edit (as the REST API Edit Issue endpoint does not support this), a Rank change is likely the only such case.
  • However, if you want the rule to run for Rank changes unrelated to a status transition, the solution is more complicated, requiring the use of the REST API:
    • when the Work Item Updated rule triggers,
    • check the {{changelog}} for the rule, and if it indicates the Rank changed,
    • use the Send Web Request action to call the REST API endpoint for Get Issue, expanding to include the recent list of changelog entries
    • depending upon rule performance...
      • the most recent (i.e., the first) entry will be the Rank change
      • if the second entry is a status change, and that log entry was created within a second or so of the first entry...this was a drag-and-drop, so stop processing the rule steps
      • otherwise, continue processing
arielei
June 30, 2025
Hey @Dmitry Alabyan
Switch the trigger from "Work Item Updated" to "Field Value Changed" and add all the fields you want to monitor.
Dmitry Alabyan
that would not be elegant, since pretty much every other change is monitored
and there is a great number of fields
arielei
June 30, 2025
Hey @Dmitry Alabyan ,
So use another method:
1. Create a CF called "LastStatus" , could be short text field.
2. Create an automation that when you change the status - copy the value to that field BUT before copied set a delay time of 4 sec.
3. Then, when you run your automation, run a compare between the current status to the CF LastStatus
This way, you'll be able to exclude status updates.
Dmitry Alabyan
not exactly. if I understand the logic correctly - there still will be a triggered Work Item Updated case
Dilip
June 30, 2025
Hi @Dmitry Alabyan
could you please elaborate more on your requirement?
also,I noticed you are eligible for 1:1 support as per your plan, feel free to reach out to Atlassian support here:https://support.atlassian.com/contact/
Dmitry Alabyan
@Dilip never tried discussing these questions with the support team to be honest. Is that within your scope?
