Flagged Issues Are Not Appear
Rabia S_
Hi all,
We have Jira Software 8.20.11 version.
And in the "Search for issues", I filtered and flagged issues are not appeared.
Is it a bug? I tried all filter ways. That are not worked for me;
1. Flagged = Impediment
2. Flagged is not EMPTY
 If it is a bug, how can I see flagged issues without JQL in Jira?
Thanks.
Florian Bonniec
Hi @Rabia S_
If you are talking about this feature, you should be able to query it using JQL. This field is not locked so the option may have been updated but is or is not empty should worked.
Regards
Rabia S_
I saw this page. But JQL isn't work. I'm adding some screenshots about my problem. The system can't find.
Florian Bonniec
Right it should work, can you try to re-index the porjet to see if it's an index issue ?
Rabia S_
Everyday, system is automaticly indexing. But any projects' flagged issues are not apear too. And I tried to indexing the project. Still I can't see any.
We have 950k issues and absolutly I could to see one
