Hi
I really feel this is a silly question, but i can't find an answer in the documentation.
In the image i have an if-else if-else on the returned status code of a webhook.
I the non branching part i also have a update statement of the field. If this was a regular programming language there is no doubt that the execution flow always executes the last update.
The graphical representation does not show that the branching execution returns to main flow.
I think that from my tests that it does. I have been looking for a clear answer in the documentation but I cant find it.
I my regular interpretation of the flow logic correct. The last statement on the regular flow path is run no matter the outcome of the if-else if-else.
Thanks for any clarification.
Best
Jens
Hi @JensH ,
I found an answer to your query here: In the Atlassian Community
I hope this helps,
Dick
By voting for helpful posts and marking answers to your question, you're helping people with similar questions find a solution more quickly. Sharing is caring applies to knowledge as well :)
