Help center loading forever
Dante Labate
Need help
I'm having trouble loading the help center of the portal, it stays in an eternal load.
The print looks like it does not find all the portals and gets stuck.
Can anybody help me?
I do not even know where to begin with
JIRA  7.1.7
SD 3.1.6
Dante Labate April 23, 2018
Let it be registered here.
My problem was related to the database, we did the restart and the problem was solved.
Matúš Klaudíny
Could you please elaborate more on what kind of db issue it was?
Dante
July 10, 2019
Hi @Matúš Klaudíny
Honestly, I do not remember, but I remember there were queues and processes stuck (zombies).
Restart the database (SQL Server), JIRA and everything returned to normal (we noticed an improvement in performance) ...
We believe that the processes that were impacting the portal were also affecting performance.
M Amine
Hi Dante,
First thing is to go to the logs in order to see what happens (Home Directory > Log > "you will find logs there".
And then you can share them and we can help.
cheers
Dante Labate
Thanks for the answer Mohammed
Which log should I look first? (I do not know in which log the items of the service desk or portal are registered)
