Help with Automation to set a field value based on certain criteria
Juliette Bramall February 7, 2025
Hello fellow Atlassian-ers :)
We have a custom field called 'Closing Category', a field called 'Test Phase' and a third field called 'Root Cause' for a bug issue type.
I've been asked to automate the 'Closing Category' which requires a conditional update based on "Root Cause" field as below,
If (Test Phase is " User Acceptance Testing" or "Production") and Status is "Closed" then
if (Root Cause = "Cutover") then Closing Category = "Production Deployment / Cutover Issue"
if (Root Cause = "Duplicate" then Closing Category = "Invalid"
if (Root Cause = "Existing Production") then Closing Category = "Existing Production issue"
if (Root Cause = "Invalid Defect") then Closing Category = "Invalid"
if (Root Cause = "Non Reproducible") then Closing Category = "Cannot be tested, no clear recreation, speculative fix"
if (Root Cause = "Requirements/Specification") then Closing Category = "Requirements change raised in pilot or rollout"}
Can anyone else me set up the automation, including triggers and components, etc. I'm a bit of an automation novice when it's anything beyond the basic :)
Thanks in advance!
Bogna Krystian_Deviniti_
@Juliette Bramall
Hey Juliette, you can set up a rule that is triggered when an issue transitions to the "Closed" status. The rule would check if the Test Phase is "User Acceptance Testing" or "Production" and if the Root Cause is "Cutover", then update the Closing Category accordingly.
Alternatively, if you're looking for a way to handle this directly within the issue form, some Jira add-ons (for example, Dynamic Forms) allow you to configure conditional behaviors. This means the Closing Category field could update in real time based on the value selections in the Test Phase and Root Cause fields while the user is filling out the transition screen- without needing a separate automation rule. This could simplify the setup
Juliette Bramall February 18, 2025
Hey @Bogna Krystian_Deviniti_
Thanks for pointing me in the direction of the add-on. Much appreciated.
Juliette Bramall February 10, 2025
sorry, IScreenshot 2025-02-10 120929.png thought I had. Here it is
Vishal Biyani
February 7, 2025
@Juliette Bramall
Please share more context for community to help you.
  • How are the values populated in Custom field "Root Cause" and "Test Phase"? is it on a status Transition of the issue or is updated manually?
  • Is the automation rule applicable for a specific issue type?
Hello @Vishal Biyani
  • Yes, it's on transition from the status Retest to the Closed status.
  • It's for bug issue types
Vishal Biyani
February 7, 2025
@Juliette Bramall
Please implement these steps and share your automation rule screen shot if you face hurdle.
1. Trigger
Add Issue Transitioned trigger
  • In from status add Retest (Should exactly match your status name)
  • In To status add Closed
2. Click on Add Action and search for Add If condition
if issue type equals Bug
3.  Add Lookup Table
Click on Add an Action and search for lookup table
  • Provide lookup table variable name say ClosingCategory
  • specify your conditions for root cause e..g key = Cutover value = Production Deployment / Cutover Issue
4. Click on Add Action and search for Add if block
In Conditions add
Field = Test Phase
Equals User Acceptance Testing
or
Field = Test Phase
Equals Production
5. Click on Add Action and search for Create Variable
Name the variable say RootCause and in smart value put
{{ ClosingCategory.get(issue.Root Cause) }}
5. Click on Add Action and search for Edit issue
In Choose field select Closing Category
and in the text box below put {{ RootCause }}
Let me know if this works for you.
When the transition happens, then you should see Closing Category updated.
Step 2. Add If condition didn't appear when searched for?
Screenshot 2025-02-07 124402.pngDo you mean this for step 2. ?
If the above is correct for step 2. What do I need to do at this stage please?
Vishal Biyani
February 7, 2025
Assume you have added Trigger. This is how it would look
Click on + Add Component and on right side you will see a screen like this
Click on IF: Add a condition
Then you will see a screen like this
select Issue fields condition highligted
Like Juliette Bramall likes this
I think I've done step 2. And am now looking at step 3. But unsure what to do for the key and value table entries.
Vishal Biyani
February 7, 2025
Variables need to be without spaces i.e. one word. So it should be ClosingCategory
in key enter enter Cutover and in value add Production Deployment / Cutover Issue
then click on + Add Entry to add remianing 5 values
Key Value
Cutover Production Deployment / Cutover Issue
Duplicate Invalid
Existing Production Existing Production issue
Invalid Defect Invalid
Non Reproducible Cannot be tested, no clear recreation, speculative fix
Requirements/Specification Requirements change raised in pilot or rollout}
Thank you so much for your help so far @Vishal Biyani
This is what I've set up. However, when I've tested it out by creating a bug with the relevant field options set as follows:
Root cause = cutover
Test phase = production
However the rule is not running according to the audit log and the Closing Category remains as 'none'.
Screenshot 2025-02-10 104832.pngScreenshot 2025-02-10 104853.pngScreenshot 2025-02-10 104902.pngScreenshot 2025-02-10 104916.pngScreenshot 2025-02-10 104932.pngScreenshot 2025-02-10 105258.png
Vishal Biyani
February 10, 2025
Can you share the audit log to understand where the rule is not hitting? Audit log is right besides Rule Details
You can see it's not even 'firing'.
Vishal Biyani
February 10, 2025
in the rule you have missed starting and ending curly braces
I've updated it as per attached. And re-tested the rule, but it's still not 'firing'?
Vishal Biyani
February 10, 2025
can you share the trigger for your rule?
Screenshot 2025-02-10 120929.pngHere it is.
Vishal Biyani
February 10, 2025
So you need to execute this transition on a bug that has Status Fixed to Closed. then only automation will get triggered.
The bug SS that you shared is already in Done status. So in this case the automation will not get triggered
I realised it wasn't triggering the rule as I've used the wrong transition. This is now corrected to be Retest to Closed.
So the audit log is showing 'success'.
However, the Closing Category is still blank/none
Vishal Biyani
February 10, 2025
This is good progress.
Can you expand the audit logs to understand where the issue is not meeting the condition?
Do validate that your case matches. Otherwise, string comparison may not work and hence field is not getting set.
Thank you for your patience with me :)
Here's the audit expansion. In the meantime I'll validate my case matches.
Vishal Biyani
February 10, 2025
Looks like Root Cause variable is not getting value. Add more log statements to check where the conditions are failing and go from there.
Can you clarify what you mean by "Add more log statements to check where the conditions are failing and go from there" please Vishal
Vishal Biyani
February 10, 2025
So wherever smart values are being created, enclose them in {{#debug}} {{/}
for example, for RootCause
{{#debug}}  {{ ClosingCategory.get(issue.Helper Issue Creation) }} {{/}
When automation is executed and value is not getting set you know the problem
BTW, WHY are you using Helper Issue Creation, you need to give your custom field name. What i gave you was an example that i created based on available fields in my instance.
I haven't used Helper Issue Creation ?
I've tried adding the debug here but am getting an error.Screenshot 2025-02-10 140932.png
Vishal Biyani
February 10, 2025
Add one more } at the end.
{{#debug}}  {{ ClosingCategory.get(issue.Helper Issue Creation) }} {{/}}
Thank you. That's now worked.
This is the latest audit log, with the debug added.
Vishal Biyani
February 10, 2025
Log shows you are getting Cutover as the value, so you are not using lookup table, while creating the RootCause variable.
Can you revisit your rule.
Juliette Bramall February 11, 2025
Screenshot 2025-02-11 081649.pngThis is the table set-up. Is this not correct?
Vishal Biyani
February 11, 2025
Table is fine. Check and share what you have in RootCause? it should be using the lookup table
Screenshot 2025-02-11 083646.pngThe id is Root Cause field.
Vishal Biyani
February 11, 2025
it should be like this
{{#debug}} {{ ClosingCategory.get(issue.customfield_19832) }} {{/}}
And re-run the automation with a new test bug issue. But the Closing Category is still not populating.
Vishal Biyani
February 11, 2025
Can you share the SS of the last step i.e edit issue Field?
Also, share the history of what Updates happened after the automation was run
The only update since last running the automation was updating to this :
Vishal Biyani
February 11, 2025
if you see the log message, RootCause is not getting value.
Add debug statement for issue.customfield_19832 to see what value it is having
I already have that in place for the variable. Do I also need to add it for the Edit issue fields?
Vishal Biyani
February 11, 2025
add a log statement specifically for  issue.customfield_19832
Need to see what else needs to be added to this variable to ensure it is picking right value
Hello Vishal
Apologies for the delay in responding to you.
Please can you explain further what you mean by a "log statement specifically for  issue.customfield_19832"?
Vishal Biyani
February 18, 2025
as the lookup is not working, need to see what is the value that is coming in automation for issue.customfield_19832
Log an action using {{issue.customfield_19832}}
I performed a test: value in the customfield = Cutover and Test Phase = Production. I transitioned the issue from Fixed to Closed. The Closing Category remained blank.
Here's the automation log:
Vishal Biyani
February 18, 2025
can you just add one more log statement and show what value is coming in {{issue.customfield_19832}}
