Help with Jira Installation In AWS instance
Kumar
December 13, 2018
HI Team,
I have installed Jira Application in AWS instance  its running sucessfully in my Instance
But its not running on Browser can you please help me how to make it sucess
here are the instructions that I have follwed for installation.
https://confluence.atlassian.com/adminjiraserver/installing-jira-applications-on-linux-from-archive-file-938846844.html?_ga=2.38056737.30577461.1544448151-641007875.1542833542
I have installed by using tar file.
Kumar
Edwin Kyalangalilwa
December 13, 2018
Hi @Kumar,
Check the security group of the instance and make sure it allows traffic to port 8080.
Kumar
December 13, 2018
Hi @Edwin Kyalangalilwa  thanks for reply
here are the screen short of instance
inbound.PNGthe ports all are open
Thansk,
Kumar
Edwin Kyalangalilwa
December 13, 2018
Ok, check the Jira log files and confirm that the application started up with no issues.
Kumar
December 13, 2018
Kumar
Edwin Kyalangalilwa
December 13, 2018
What are you seeing in the browser when accessing from <instance-ip>:8080?
Kumar
December 13, 2018
Hi @Edwin Kyalangalilwa  I have entered my ip  : 8080
this is message its showing
The  thing is previously i have installed jira but i have done something and its also gone so I have deleted all the jira files that installed
and I have installed newly
In the Home Directory there is no "dbconfig" file is not there
Kumar
