Help with project automation
tianchi June 7, 2022
Hi Community,
I want to automatically calculate how many days has an issue been created.
What I've done is to create a field called "创建日期" (sorry in Chinese) which automatically pick the date of when this issue was created. And now I'd like another field to always calculate "the date of today" minus ”创建日期“.
How to set the automation to achieve it?
Thanks a lot.
tianchi June 8, 2022
Hi Ollie,
Thanks for the reply, but what I want is not to calculate the difference between today and the issue created date, I want to calculate the difference between today and one specific field which is in date format. How can I make it?
Thanks!
Almost there..I put like this: {{now.diff(issue.fields.创建日期).days}}
But the result is a negative value. How can I reverse it to positive?JIRA.png
Hi Ollie,
I want to tigger the automation every 5minutes, but when I set the trigger, there is an error. How can I correct it?
