Help with validator length limit
Angel
Hi!
I wanted to limite a text-field (multi-line) to max 1000 characters on creation transition, in scriptrunner I tried with this:
cfValues['customfield_10202'].length() < 1000
error: cannot evaluate "cfValues"
issue.customfield_10202.lenght < 1000?  true: false
error:  "issue.customfield_10202.length < 1000\" - operator \"<\" is not applicable to types: null and Number"
Would anyone help me with the correct expresion or I need cast the value of customfield?
Regards
Maciej Dudziak _Forgappify_
Hi @Angel
If you are one cloud, then your custom validator most likely is using Jira expression. In case of multi line text, it can be tricky, because it may be an ADF object. Here is an example how it can be handled:
let plainTextValue = value => typeof value == 'Map' ? new RichText(value).plainText : value ;
issue.customfield_10202 != null && plainTextValue(issue.customfield_10202).length < 1000
If you are looking for more examples, check out our Jira expressions library which includes a variety of useful examples.
Cheers
Angel
it works for me
Thanks!
Hi @Angel
Hope you're doing well! I just wanted to share that we've released what we call the 'Ultimate Validator,' which takes the burden of learning Jira Expressions off your shoulders. Below is an example of how a configuration looks when validating that a text field's character count is less than 1000.
I am leaving a link to the app's documentation if you are interested.
Cheers
Tuncay Senturk _Snapbytes_
Hi @Angel
The custom fields may return null if they are not set, or their data type might not match the operation you're trying to perform.
Below is how I would code during a creation transition to limit a multi-line text field to a maximum of 1000 characters. Bear in mind that I haven't tested the code, but it is worth trying!
def customFieldValue = issue.getCustomFieldValue(customFieldManager.getCustomFieldObject('customfield_10202'))
if (customFieldValue && customFieldValue.length() <= 1000) {
return true
} else {
invalidInputException.addError("customfield_10202", "The text field exceeds the maximum allowed length of 1000 characters.")
return false
Angel
I get this error when I tried with your example
2024-12-17 12_29_08-Añadir una transición de flujo de trabajo Validator - Jira.png
