How do I search a Remote System Reference custom field?
Erik McClenahan
July 8, 2014
I've added a custom field of type Remote System Reference. I can see this field appear on my JIRA items (like Bugs or New Features) but I cannot use the search to find JIRA items by the values I see in this custom field.
For example, if the value for my custom Remote System Reference field shows up as "Ticket #200 - Bad things 'happened'", I cannot find the JIRA item by using either the Basic or Advanced search.
In the Basic search, I pick my custom field from the More dropdown control and then enter Ticket #200 - Bad things 'happened' as the value and click the Update button (I have no other filter criteria). Nothing returns.
In the Advanced search, I type this (below) and nothing returns:
cf[10400] = "Ticket #200 - Bad things 'happened'"
I've even tried escaping the single quotes but that didn't make any difference.
Mayur Ingale May 8, 2019
Guys, have you got any pointer to fetch Remote System Reference field in groovy script.
I'm trying to add a scripted validator for this field type.
Katy Kelly
May 9, 2019
Hi Mayur,
You should be able to use:
com.atlassian.jira.issue.link.RemoteIssueLinkManager
Srikanth Gannavarapu
February 9, 2016
HI we are also facing the same issue, anyone has answer for this?
