Hi
Currently, I have a rule when an issue is marked with a custom status of "BLOCKED" the issue will be flagged. I am curious, if it is possible to "unflag" the issue using Jira Automation? That way I have a rule that is To Flag(as stated earlier and seen on screenshot) and To Unflag(what I want to set up).
To note, I did create post function in the workflow that clears out the flag when it transitions out of that custom status. Although that is not what I am asking about.
Unless I am missing something, just do the opposite. Change your trigger to when you want it to happen, set a condition for flagged issues, and then edit the issue field again and remove the flagged option.
Looks good. Let me know if you encounter any issues.
