How to add more fields to a child issue in Jira
prakashmurugesan January 30, 2018
Is it possible to add more custom fileds to a child issue create from a parent issue in jira
in the above screenshot i can see values of Issue ID  Summary Field Value Priority Status
respectively.
i want to add few more custom fields in the child issue.  any suggestions?
Armando Gomez
August 21, 2018
It is an strange answer asking more, you should answer how can we "add more custom fileds to a child issue create from a parent issue in jira" as in the text and if this solution also apply to linked issues as in the attached image.
Why? You just answer with a question to clarify but you didnt keep a track and answer in the next confirmation, since January :S
THE ANSWER IS YOU CANT!
You might also read the next topic https://community.atlassian.com/t5/Jira-questions/Add-fields-to-Jira-Child-Issues-list-not-sub-tasks/qaq-p/820727
prakashmurugesan August 21, 2018
@Armando Gomez  thanks for your reply. i found the add on issue matrix plugin for implementing this functionality . but have not tried this functionality since this was least priority at this moment.
Sreenivasaraju P
January 30, 2018
These are linked issues, not the child issue (sub tasks).  Please let us know, you want to set columns for linked issues or child issue(sub tasks).
Hi Sreeni,
i wanted to add/set columns for linked issues.
any suggestions?
