How to clone Epic with children by using automation rule?
Andrey Rudnev
Hello everyone. I'm trying to create the following automatic rule for Jira Cloud: the rule should copy the epic along with all the issues included in it. Rule should be manual. Maybe you could help me with the logic of the rule? Plugins are not interested, only the rule. Thanks for your help. I am attaching a screen of my work.
2 accepted
Megan Moulton
June 13, 2023
Appreciate this thread for steering me into the right direction. Here's what I ended up doing that worked (This only clones the epic and children, not the children's sub-tasks)
2023-06-13 14_41_24-Automation - Jira Service Management.png2023-06-13 14_41_43-Automation - Jira Service Management.png2023-06-13 14_41_49-Automation - Jira Service Management.png2023-06-13 14_41_57-Automation - Jira Service Management.png
Nancy Tsai April 2, 2024
How to add the "For stories (or other issues in epic) without branching out from "Create variable?
mohit jangid December 11, 2024
This really helpful, but I want to clone the sub-tasks of stories as well, need help.
Andrey Rudnev
I found my own solution for the problem:
Laura Franceschini March 3, 2023
Hi all, @Andrey Rudnev I have tested it and somehow works. However it does not clone the Status (I am cloning from one project specific Epics - using a JQL - to another project) have exactly the same workflow (and Issue types for all it matters)
Two question here:
1. it does not clone the status. All in Backlog. How come?
2. I am not sure whether I should include in JQL the related child or not
Laura
Like Chris.Sterba likes this
Jack Brickey
You might find the answer from Alexis useful in this similar post - Automation-for-Jira-Clone-Epic-Story-and-Sub-tasks
Andrey Rudnev
Thank for your advice.
