How to copy a template project with settings, schemes, workflows, fields and layouts
Kirk Clarke July 23, 2019
Hi, I have created and configured a project as a template for others. However, when I created a new project and selected the existing one as the template no board was created for the new project. I have no opttion to add a board, all seem to force me to create a new project.
Although the schemes look the same in project settings-Summary, the issue fields are different.
Curiously, when opening the example issue on the new project the Acceptance Criteria field displays for a second then disapears.
Both projects use the exact same issue layout.
Am I missing something?
elenushhh
July 23, 2019
Hello @Kirk Clarke
I've never created a project as a template for upcoming projects, but what I did to make all the work easier was to :
- Created a basic permission scheme ( where I add only the groups, in my case our internal devs group, and external clients to have access exactly for what we want)
- Created a workflow
- Issue layouts
- Screens
*Whenever I create a new project, I use a copy and rename it after the project.
Kirk Clarke July 24, 2019
Hi Elena,
Thanks for getting back to me. I've figured out how to add a board now.
Creating a permission scheme is a good idea!
I was able to create projects and add a board by saving a filter as a board.
Then configuring the issue layout by following the Where is my field? link
Thanks again.
