Hi @Steve_G
As @Tansu Akdeniz suggested, click the 3 dots next to the automation rule and click copy. This will make a copy of the automation rule on a project level.
After that you can change the scope of the project in the rule details to your second project if you're trying to keep it specifically to these 2 projects.
This can be done through the global automation page (the option is there under the current project scope when you click into the copied rule).
However if you're going to keep the rule exactly the same, multiple project scope is advisable as its more efficient but its entirely up to you.
If you follow these steps, you'll have the same automation rule in 2 projects of your choice independently of each other.
Hope this helps.
Kind Regards,
Ash
Hi @Steve_G
What about changing the rule scope from single project to multiple project?
If you really need a copy, simply click three dots and click copy and configure the details for your other project.
Thanks @Tansu Akdeniz for the quick response.
Changing the rule scope would work in some cases. However, I would like to customize the copied rule in the second project.
The copy action in the three dots seems to only allow me to publish the copy in the same project.
Can you please try in global automation page (System -> Global Automation)? It should allow you change the scope after publishing the copy.
I'll need to work with my Admin team since I don't have access to global automations.
Thanks @Tansu Akdeniz and @Ash Yadav - both of your responses have helped me learn something new today.
hi @Steve_G ,
I just saw this youtube video for importing exporting the automation rules. Looks like you still need to have access to global rule settings but then you can customize it as needed within projects.
Hope this helps,
Shweta
