Hi
Is it possible to limit JIRA JQL find only random 10 or last 10 issues?
project = KP AND created >= startOfDay("-24h") and status = "Resolved (SD)"
Right now it find all issues what are created -24hours and status Resolved but i like to find only random 10 issues for NPS Survey
Dear @Urmo Luts,
I don't no of any Jira feature in the UI but you can do:
so long
Thomas
Maybe it is to hard to tell but i think that is it possible that i create custom field "NPS algnumber" where i give every day at 00:01 value 1 (Automation JIRA i set every day same value = 1).
Then i create another custom field "NPS number" what get value from "NPS algnumber" field and with workflow transition i give value:
Then i was thinking that i change "NPS algnumber" from "NPS number" increase by 1 unit. It should be 2. But it wont write over it :(
My idea is that i make one field what counts form 1 to 10. When same day NPS survey have send out surveys no more will send out. But right now i dont have idea, how to really create it so it will work...
Any idea?
Dear @Urmo Luts,
nop - sorry - I am not familiar with "Automation for Jira". But if you manage to alter one field only for the latest 10 then you can adapt your JQL to this custom field.
So long
Thomas
