How to include SLAs for public holidays in JIRA Service Desk?
Swarna Radha
I want to include public holidays in my Slas, as some agents work during public holidays.
Is there a way to cater for public holidays in JIRA Service Desk?
Thanks and Regards,
Swarna
Alexey Matveev
November 6, 2017
You need to define a different calendar for the agents.
Swarna Radha
But these holidays exclude SLAs but i want to include holidays in my SLAs.
RianS
November 7, 2017
If you have two calendars, one with Holidays included and one without the holidays defined. You assign the calendar with the holidays defined to the SLA's that you want to ignore holiday and it will continue to run during holidays.
SLAs that should stop on holidays should be assigned the Calendar with the holidays defined.
Swarna Radha
If one calendar consists of holidays, how i am going to include the holiday dates in the calendar?
For example if i add the holiday date in the calendar, it will exclude the SLAs.
How slas will know if that it is a public holiday?
Swarna
RianS
December 7, 2017
Each SLA is associated with a particular calendar. You can have multiple calendars defined in the system. For each SLA, you can have different calendars. So, if you have a particular SLA that should ignore holidays, you assign the calendar that has no holidays defined. For another SLA that should ignore holidays, you assign that SLA the calendar with holidays defined.
