How to stop repetition of automation rule in jira cloud
Pantham Akhil
Hello everyone I have implemented a automation rule which creates a checklist when an issue transitioned from on status to another it's working fine but the Problem is when a user is want to re transitioned the status it will creates another duplicate checklist how to prevent this problem. Please help me out ..
Thank you
Vishwas
February 1, 2022
One possible solution would be to create a custom field, so when the ticket gets transitioned set that custom field to some value in the same rule of automation.
Add a condition in the rule before creating checklist to check if the custom field has that value in JQL( Example "Reopened" = No) then do the automation or else don't do. This would ideally avoid duplication.
Please check out this similar thread too https://community.atlassian.com/t5/Marketplace-Apps-Integrations/Automation-for-JIRA-how-to-stop-rule-repetition-for-the-same/qaq-p/1530996
Let me know in case of questions..
Pantham Akhil
Should I need to add a custom field which is a multi select field and need to add default value to that field or else can you please elaborate this one
TIA
Vishwas
February 2, 2022
Multiselect is not required, just a select value is fine like yes or no kind of options.
So for the first time the transition happens, set the custom field value to yes in the same automation in another action.
Like Pantham Akhil likes this
Pantham Akhil
Hi @Vishwas
Still unable to configure can you please give me your email id or else can you msg me panthamakhil@gmail.com
Thank you!
Vishwas
February 3, 2022
Let me write the rule and send it
Vishwas
February 3, 2022
Hey @Pantham Akhil
Automation rule is ready.
Before doing this i created a field called "Issue Transitioned ?" with Yes and No as dropdown values and added the field to edit screen of the project.
Try this and let me know in case of any issues.
Vishwas
Like # people like this
Pantham Akhil
Unable to find the custom field which I was set in the rule 16439596842734761115682760955246.jpg
Vishwas
February 3, 2022
please check my rule. I haven't put the edit condition at the top. We need to put a JQL condition there. Then at last the edit action.
Also add the field created to the screen of the project.
Padah JIRA February 3, 2022
meet.google.com/rai-mgnc-axp if you free can you please join this meeting once?
Sukruth M S
February 1, 2022
Hello @Pantham Akhil , you can  manually turn off/disable the automation after it is executed correctly as defined by you when you don't need.
Hope this helps you, @Pantham Akhil
Sukruth M S
Vishwas
February 1, 2022
This doesn't make sense, disabling rule is fine ?. It entirely stops the running of automation, isn't it ?.
What if the checklist has to be created for other issues, stopping isn't a solution. As the whole purpose of automation written for creating checklist is defeated.
from the requirement @Pantham Akhil  is asking is there way to ignore the issues for which the automation rule has been executed at least once for them.
Pantham Akhil
Yeah @Vishwas  that's correct disabling rule doesn't make any sense actually I want prevent the duplicate creation of checklist when an user go back to previous status and doing the same transition the rule again creating a new checklist ...so I want to stop that duplication
Like Vishwas likes this
Vishwas
February 1, 2022
Hey @Pantham Akhil
Got your point.
Please send me the rule that's already running, let me see and suggest you.
Vishwas
Jack Hunter [HeroCoders]
You need to set proper rule conditions, so it doesn't start when you don't need it.
Pantham Akhil
Pantham Akhil
Here is the rule @Vishwas please check ...
Pantham Akhil
Unable to put an exact condition @Jack Hunter [HeroCoders]  can you please help me in this
Please show also the edit issue details on the screenshot.
Guaraci Nakamura May 19, 2022
@Pantham Akhil your automation is very close to the one i created, however ALL issues are triggered, consuming the execution limit. How do you solved this point?
