I am trying to use confiforms to link to my current jira project however I can't figure out how to write the code so that way they are linked. Ideally, I want the attachments from the confiform to be submitted in the Jira Project. Below I have posted my code:
{ "fields": { "project": { "key": "ILS" }, "summary": "[entry.Summary]", "attachment": "[entry.Attachments]", "description": "[entry.Description]", "issuetype": { "name": "Task" } } } |
Please see the following tutorial on Creating Jira issues in Confluence using ConfiForms @Fred Williams
It also shows you how to send over attachments...
Quick answer is to drop a ConfiForms Field (referencing your file/attachments field) inside the same IFTTT macro body what creates the Jira issue and you are good
I don't see a Confiforms Fields. Only Confiforms Forms Field.
Is that the one?
Yes, Confiforms Forms Field is the name of the macro
Let us know if you need any help, you can contact our support via https://wiki.vertuna.com/display/VERTUNA/Support+Request+Form
While this works for users logged into Confluence, for users not logged in a whole raft of permission related errors are thrown (yes, anonymous is set). My counterpart moved to the IFTT webservice action to get around this, but that does not support attachmenst in the same way
all my search for attaching files using the rest API result in Java, PHP etc. answers
How do I either:
1) use the IFFT Create Jira action in a form used by non-confluence users
2) attach file using the IFFT Webservice action
Hi @Paul Ward
With built-in IFTTT action to create Jira Issues (which uses Application link) you have an easy way to send attachments to created Jira ticket
This relies on the application link between your Jira and Confluence and uses that as an auth story.
When you use generic web services requests then there is no magic done around uploading attachments... as well.. the request is generic and you tell it what to do
Below is the storage format for the workflow that creates Jira ticket, saves it back to ConfiForms entry and uploads the file as attachment and creates a remote link
Everything uses the webservices connection
<ac:structured-macro ac:macro-id="634f4a34-b8ba-464d-b222-e123d65cc4e0" ac:name="confiform" ac:schema-version="1">
<ac:parameter ac:name="formName">ji</ac:parameter>
<ac:parameter ac:name="showOnlyOwnRecords">true</ac:parameter>
<ac:parameter ac:name="registrationFormTitle">Create JIRA issue with ConfiForms Webservice connection</ac:parameter>
<ac:rich-text-body>
<ac:structured-macro ac:macro-id="dd25632e-211e-4820-8754-836d4ade9236" ac:name="confiform-entry-register" ac:schema-version="1">
<ac:parameter ac:name="overrideSaveButtonLabel">Create</ac:parameter>
<ac:parameter ac:name="registrationButtonLabel">Register me</ac:parameter>
<ac:parameter ac:name="embedded">true</ac:parameter>
<ac:parameter ac:name="atlassian-macro-output-type">INLINE</ac:parameter>
<ac:rich-text-body>
<p>
<br/>
</p>
</ac:rich-text-body>
</ac:structured-macro>
<p>
<ac:structured-macro ac:macro-id="8a572845-1d28-4560-a4d8-f8102317e419" ac:name="confiform-field-definition" ac:schema-version="1">
<ac:parameter ac:name="fieldName">summary</ac:parameter>
<ac:parameter ac:name="fieldLabel">Summary</ac:parameter>
<ac:parameter ac:name="type">text</ac:parameter>
</p>
<p>
<ac:structured-macro ac:macro-id="2e5a8660-272b-43f6-801d-a3131c3665c5" ac:name="confiform-field-definition" ac:schema-version="1">
<ac:parameter ac:name="fieldName">desc1</ac:parameter>
<ac:parameter ac:name="fieldLabel">Description</ac:parameter>
</p>
<p>
<ac:structured-macro ac:macro-id="7d641f3b-1fd7-4e47-a63e-a2b040782730" ac:name="confiform-field-definition" ac:schema-version="1">
<ac:parameter ac:name="fieldName">desc2</ac:parameter>
<ac:parameter ac:name="fieldLabel">More details:</ac:parameter>
<ac:parameter ac:name="type">textarea</ac:parameter>
</p>
<p>
<ac:structured-macro ac:macro-id="7c8f347e-7704-441f-92f2-990cac31a7d5" ac:name="confiform-field-definition" ac:schema-version="1">
<ac:parameter ac:name="css">width:100px;</ac:parameter>
<ac:parameter ac:name="fieldName">jk</ac:parameter>
<ac:parameter ac:name="fieldLabel">Jira key</ac:parameter>
<ac:parameter ac:name="type">read_only</ac:parameter>
</p>
<p>
<ac:structured-macro ac:macro-id="a06f0ccf-0e36-4d07-b47d-cb38a345c0fe" ac:name="confiform-field-definition-rules" ac:schema-version="1">
<ac:parameter ac:name="condition">id:[empty]</ac:parameter>
<ac:parameter ac:name="action">Hide field</ac:parameter>
</p>
<p>
<ac:structured-macro ac:macro-id="1b02c04d-3480-4397-9ddb-9b0e556b4351" ac:name="confiform-field-definition" ac:schema-version="1">
<ac:parameter ac:name="fieldName">fi</ac:parameter>
<ac:parameter ac:name="fieldLabel">fi</ac:parameter>
<ac:parameter ac:name="type">file</ac:parameter>
</p>
<ac:structured-macro ac:macro-id="53fe3481-065d-41c4-be5d-a7a1268b0450" ac:name="confiform-ifttt" ac:schema-version="1">
<ac:parameter ac:name="action">WebService Request</ac:parameter>
<ac:parameter ac:name="extras">4bb4c41a51f289a07507d50a1b841a4d</ac:parameter>
<ac:parameter ac:name="event">onCreated</ac:parameter>
<ac:parameter ac:name="title">/rest/api/2/issue/</ac:parameter>
<ac:parameter ac:name="extras2">X-Atlassian-Token: no-check;Content-Type: application/json;Content-Type:charset=UTF-8</ac:parameter>
<ac:parameter ac:name="who">POST</ac:parameter>
<ac:rich-text-body>
<ac:structured-macro ac:macro-id="46d25e82-d4db-4e38-9b96-f5c6159c473f" ac:name="noformat" ac:schema-version="1">
<ac:plain-text-body><![CDATA[{
"fields": {
"project":
"key": "JTEST"
"summary": "[entry.summary.escapeJSON]",
"assignee":{"name":"admin"},
"description": "[entry.desc1.escapeJSON] \n [entry.desc2.escapeJSON]",
"issuetype": {
"name": "Bug"
}]]></ac:plain-text-body>
<p>
<br/>
</p>
<p>
<br/>
</p>
<ac:structured-macro ac:macro-id="f00edb26-9174-4f7a-9570-d598e92dce10" ac:name="confiform-ifttt" ac:schema-version="1">
<ac:parameter ac:name="extras4">true</ac:parameter>
<ac:parameter ac:name="action">Create ConfiForms Entry</ac:parameter>
<ac:parameter ac:name="title">entryId=[entry.id]&jk=${iftttResult_0}</ac:parameter>
<ac:rich-text-body>
<p>
<br/>
</p>
<ac:structured-macro ac:macro-id="fe3beac3-95ef-49ae-b42c-e3168a2f57b7" ac:name="confiform-ifttt" ac:schema-version="1">
<ac:parameter ac:name="title">/rest/api/latest/issue/[entry.jk.asJSON.key]/attachments</ac:parameter>
<ac:parameter ac:name="additionalContext">file</ac:parameter>
<ac:parameter ac:name="extras2">X-Atlassian-Token: no-check;</ac:parameter>
<ac:rich-text-body>
<p>
<ac:structured-macro ac:macro-id="1271c70c-7c2b-4ed2-b009-d2e731ec4a8b" ac:name="confiform-field" ac:schema-version="1">
</p>
<p>
<br/>
</p>
<ac:structured-macro ac:macro-id="d4d6ee84-0f33-4713-b0c4-04baad175345" ac:name="confiform-ifttt" ac:schema-version="1">
<ac:parameter ac:name="title">/rest/api/latest/issue/[entry.jk.asJSON.key]/remotelink</ac:parameter>
<ac:rich-text-body>
<ac:structured-macro ac:macro-id="56a89f71-7d60-496a-ab45-2d6f6db4bd34" ac:name="noformat" ac:schema-version="1">
"object": {
"url":"https://wiki.vertuna.com/pages/viewpage.action?pageId=19104427",
"title":"[entry._page.title.escapeJSON]"
<ac:structured-macro ac:macro-id="d309c641-56ef-46cb-b01f-19590d41605e" ac:name="confiform-table" ac:schema-version="1">
<ac:rich-text-body>
<p>
<ac:structured-macro ac:macro-id="bb4766d6-cbfe-40c6-ace4-f3dcd21dcc99" ac:name="confiform-field" ac:schema-version="1">
<ac:parameter ac:name="fieldName">jk.asJSON.key</ac:parameter>
</p>
<p>
<ac:structured-macro ac:macro-id="18b7e9fe-30c3-4a04-886e-6a47446af441" ac:name="confiform-field" ac:schema-version="1">
<ac:parameter ac:name="fieldName">created</ac:parameter>
</p>
Hi @Paul Ward
<ac:rich-text-body>
<ac:rich-text-body>
<p>
<br/>
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<ac:rich-text-body>
"fields": {
"project":
"key": "JTEST"
"issuetype": {
"name": "Bug"
<p>
<br/>
</p>
<p>
<br/>
</p>
<ac:rich-text-body>
<p>
<br/>
</p>
<ac:rich-text-body>
<p>
</p>
<p>
<br/>
</p>
<ac:rich-text-body>
"object": {
<ac:rich-text-body>
<p>
</p>
<p>
</p>
Alex - the links to your reply leads to a 404 and the content was chopped short in the email itself. Could you please respond again, perhaps to my post here: https://community.atlassian.com/t5/Jira-questions/Attaching-files-to-Jira-issues-from-Confluence-offline-user/qaq-p/888576
cheers
It's weird, as I have provided you with a complete answer showing how to configure IFTTTs to do that.. and it was visible here for me, but now has disappeared
some anti-spam or something
how the hell I can provide the answer if this get's stripped !? Ohh
