I have client requirement.I have to update Title and Description in jira using rest services.
Could you please provide me corresponding rest api as well as request payload for update and Title and description.
Nageswara K.
Hi Alexey..
I have constructed requested rest service following to update summary.
/rest/api/2/issue/10206/editmeta
This is my request payload.
"update":
"summary":"Thi is my update summary"
getting following error.
You should use PUT /rest/api/2/issue/{issueIdOrKey}
not the eidtmeta
I have removed editmeta.
Request payload is :
"update":
but getting below error.
"errorMessages": [
"Can not deserialize instance of java.util.ArrayList out of VALUE_STRING token\n at [Source: org.apache.catalina.connector.CoyoteInputStream@1440b411; line: 4, column: 1] (through reference chain: com.atlassian.jira.rest.v2.issue.IssueUpdateBean[\"update\"])"
Hi Alexey.
Could you please provide me both cases like Title and Description .
Rest services URLs and corresponding payloads.
that should be great.
Nageswara K.
{"fields":{"summary":"This is a shorthand for a set operation on the summary field","description":"description changed"}}
PUT /rest/api/2/issue/issuekey
Thank you Alexey..
working as expected..
Nageswara K.
