×In this case, the field (we'll call it Field #3) is populated via an automation which takes the input of two other custom fields (Fields #1 and #2), does a mathematical computation, and outputs the result as a numerical value in Field #3.
However, once the value is updated, you can change it manually, which is bad. Since this value is being used elsewhere, it needs to stay the result of the computation. Therefore, I want to make Field #3 read-only.
Any thoughts?
Hi Brent,
No, you cannot make a custom field read only in Next-gen.
@Sebastian Penhouet - I am not sure as I don't really use Team-managed projects.
And not sure if this covers it, but here is an open request:
Hi @John Funk maybe you copied the wrong link? The issue you linked is unrelated to the issue described here.
Here ya go:
Hi @Katarzyna I don't see how the issue you linked has something to do with the problem described here.
Currently, in next-gen you can't use global custom fields. So to make them read-only, Atlassian must add support for custom fields firstly.
There are already custom fields in next-gen projects (just not global ones). For them to be read-only they do not need to be global.
