Is it possible to ammend a string to a customField?
Matheus F. Nishida April 11, 2022
Hi All,
My idea here is to ammend any hardcoded string, e.g. "Hello World" to a customField inside JIRA smart value (JIRA Automation web request).
Does anyone knows if that's possible?
Bill Sheboy
April 11, 2022
Hi @Matheus F. Nishida
Would you please provide more details about what you are trying to accomplish/dynamically update: the URL, the request data, something else?
For example, in another thread, I learned it does not appear to be possible to dynamically update (or even include) an issue key in the URL for a web request action to the Jira REST API.  So if that is what you wanted to do...it does not appear to work for Jira Cloud.
Matheus F. Nishida April 12, 2022
I'm working on a automation for JIRA function, to perform a web request to an external service.
The issue I'm facing is to build the JSON request, with custom fields.
For example this is the POST request body:
    "field1": {{issue.custom_field1.value}},
    "field2": "Hello World" + {{issue.custom_field2.value}}     <----
How can I concatenate an string with a custom field inside a JSON POST request body?
Hi Bill
I was able to solve my issue by concatenating the JSON body as per using the same template from the link you shared:
"testField1":"Hello World {{ issue.customfield1.value }}",
And it worked!
Like Bill Sheboy likes this
Bill Sheboy
April 12, 2022
Matheus, I am glad to learn you got it to work that way.  There is also a concat() function to help with combining smart values, as described here:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/#concat-String-str-
I read that documentation, however it's not possible to concat a String first and, then, the custom field, right?
I can concat customfield with a "Hello World", but cannot do that the other way around, e.g. "Hello World" with customField
Bill Sheboy
April 12, 2022
That is correct.  As a work-around, you could first set the literal string to a Created Variable, and then concat() to that.
Like Matheus F. Nishida likes this
