Is it possible to create Visual Multi-line text box?
Jeremy Price
January 9, 2020
The Description field as well as the Environment standard fields in Jira give you the option of having a visual or text based response in the box.
When I create a multi line text box custom field I don't get those extra options on my text box.
Is there away for me to have those options on my custom field multi line box as well?
Nic Brough -Adaptavist-
January 9, 2020
If you log in as an admin, go find the "field configuration" for this project and issue type (easiest to go via the project header and settings), then you should be able to change the "renderer" for the Acceptance Criteria from "plain" to "rich" or "wiki" (not sure which you might have)
Jeremy Price
January 9, 2020
Thank you for this. Forgot about the field config option.
January 9, 2020
Glad to help!
We all forget bits of Jira at times, irrespective of experience!
Like Jeremy Price likes this
parthiban.selvaraj March 8, 2020
Hi @Nic Brough -Adaptavist- ,
Can we set "Visual" tab as default for all users ?
Parthiban
