Is there a way to scedhule an automation rule to create issues for every customer I have in the list of customer?
For example as a survey, i want to create automatic request where the reporter is my customer ( instead of creating manually 100 requests)
Hi @Rita Saad YOUNES ,
there is no way OOTB to do this within JSM and automation alone. You would need to look to an add-on for this capability. If you were simply wanting to get more information as a customer satisfaction survey when an issue is resolved, you could add a form with more questions associated.
Hello @Jack Brickey
I mean by customers the user they have license in JIRA.
U think is there a way so I can get the users and create for them an automation rule?
I do not know any way of achieving that With automation. I don't really understand the use case for this. Why do you want to create an issue for every customer? Further how often would you do this? Depending on your requirements, it might be that you could create a CSV file and import that as needed to create those issues. Basically, you would have a row for each customer. You could export the customers to create the initial CSV
In Fact I would like to create issues for the employee in the company every 3 month to make the appraisal , instead of creating the request as an automation for every employee so I make 70 automation rules, I would like to create one rule who can create 70 issues. I hope the idea is clear now
I don't know of any way of creating an automation rule to do this. I would suggest again that you consider using CSV to accomplish this. I would simply create a calendar event that reminded me to create the issues and I would have a CSV file ready to import. you certainly could look at the API's and come up with a solution to automate it outside of the product.
Hi!
I also wonder about what problem is being solved, and if Jira is a good place to solve it. Regardless of that...
Theoretically, one could call the admin REST API to get all users with the Send Web Request action, parse the response, iterate over the values, and then perform actions.
The API token created (and rule actor) would need sufficient permissions to access the users with this user function.
Please note: rules are limited to 100 issues / items when branching (and searching) and so I suspect such a rule would not work as intended if there are ever more than 100 users.
