×I have a JIRA automation rule to update comment on custom field change in JIRA. The rule is also triggering when the custom field is changed via REST API in JIRA. i want to restrict the trigger via REST API. Is there any way to do so?
Hi @Jira
Jira will notify updates with the same mechanism regardless of the way it was triggered.
If you have a specific system user accessing via REST API you may be able to use the {{initiator}} smart value to select by user. i.e. select or ignore the API user.
Thanks @Tom Lister, expanding on your helpful suggestion, you could use that {{initiator}} smart value like this, for instance:
