JIRA integration with Business process management(BPM)
Ravi K November 23, 2019
Hi Team,
   We are planned to integrate BPM with JIRA. Please anyone help me with this. Below flow we required to implement.
[Requester raise the request in Smart process ]
<Site Officer approval >
<Manager approval>
[Support request create automatically in JIRA]
(Ticket create under "HTC -> Security -> NOIDA"
Manual ticket creation blocked for this category )
[HTC team execute the request and update the Status in JIRA]
Trinadh
(JIRA Manager)
2 accepted
Hello Gonchik,
Thanks for the early reply in BPM tool from Wrkie Application we are planning to integrate Jira is it possible to integrate if Yes please suggest me the steps so it can help for us in integrating with that tool
Thanks for understanding!!!!
Trinadh
Jira Manger
Gonchik Tsymzhitov
Ravi K November 25, 2019
Hello Gonchik,
Thanks for reply and thanks for the article
The team is integrating from BPM tool (Process Maker) in BPM tool to JIRA
Please help us to give the link and steps for the integration process form Process Maker to JIRA
These will help us lot for our organization
Trinadh
JIRA Manger
Bhargav November 27, 2019
I want the same requirement can anyone share the reference links to integrate the procces maker with jira?
Waiting for suggested links...
Gonchik Tsymzhitov
Hi!
Could you provide, please, what exactly BPM tool you are speaking?
Anastasiia_Piliugina
February 13, 2020
Did anyone had successful experience of any BPM integrated into JIRA? Thanks.
Blake Thorne
July 27, 2021
Hey @Anastasiia_Piliugina
Blake from Process Street here (formally in Atlassian :) )
We learned a lot recently integrating our modern process management tool with Jira. A few considerations we found helpful with connecting BPM thinking into Jira.
As opposed to project management, with Process Management you typically have higher degree of knowledge ahead of time on exactly what needs to be done and what way.  That's why a typically workflow status in Jira might be "In progress" where a status in a BPM environment is going to be a lot more specific. The other key we found is in how integrated the content and documentation is with the workflow. For Atlassian environments you can certainly do this with Confluence. As you move deeper into BPM thinking, we find having process documentation integrated into the workflow steps (as opposed to a click away) becomes key.
I would also think of areas where process management and project management connect. For example, a bug submission workflow may be a detailed process (you know exactly what needs to be done and what knowledge needs to be shared in order to submit a bug), but the actual diagnosing the issue and fixing the bug is a project (what specifically needs to be done is unique and not known up front).This is how we use Process Street and Jira on our team.
Like Anastasiia_Piliugina likes this
Florian Bauer
February 14, 2023
Many BPM solutions provide Jira connectors to create a Jira issue related to a process activity. But this means always maintaining another platform and its integration points.
Jira is a great way to manage workflows within a single ticket, but it is not a BPMS that operates a process mode, multiple activities, actions, and decisions.
I'd like to mention a way to make Jira a real BPM system:
Flower - Process Automation is a Jira app from the Atlassian Marketplace and lets you model a process in BPMN. When launching a process instance based on the model, Flower creates an issue for each activity and visualizes the status in the BPMN graphic through the execution.
Flower supports the entire BPM lifecycle, from BPMN modeling, through process simulation to process monitoring.
Like Tanja likes this
