JMWE: Conflicting results when using same code in workflow validator & copy issue field postfunction
Steven Rhodes
I have a JMWE Field Required Validator in a workflow that successfully requires a user to provide a field if the value of another field is true. This field is a simple select dropdown with Yes and No.
In the same workflow I have two post functions that uses the same code to determine whether to Copy Issue Fields from another issue, and a Create Issue post function. This returns false. This Nunjucks code is identical except for the necessity of providing {{. What am I doing wrong?
David Fischer
Hi @Steven Rhodes
The syntax is different between post functions and conditions/Validators, because the latter are limited to Atlassian's Jira expressions.
You can use the Issue Fields help tab of the editor to find out how to access your field from Nunjucks.
Steven Rhodes
I followed your advice, and yes it led me to the fact that I needed the fields part
{{ issue.fields.customfield_20423.value == "Yes" }}
So I'm accepting this answer.
Tom Lister
Try
{{ issue.fields.customfield_20423 == "Yes" }}
in the nunchuck condition
Steven Rhodes
I saw @David Fischer 's answer first, but this was definitely the right direction. However, it didnt work because I would still need the .value on the end. I probably would have worked it out from your answer tho as I'd already stated the suffix in my attempt. Thanks!
Like Tom Lister likes this
