JMWE PostFunctions: Iterating through more than 100 issues
Ahmad Sidawi
I'm wondering if its possible to create more than 100 issues through post functions. I know that Jira 'paginates' queries to only return 100 issues at a time, so I'm trying to figure out how to keep calling the next 100 issues. The 'startAt' variable didn't do what it does when performing automations through Python, it instead only starts value in the first 100. Here's what I've got now:
{% for i in range(1,(("project = X  and issuetype = Task order by updated desc")|searchIssues(maxResults =100, startAt=0) | length)) %}
{{i}},
{% endfor %}
What I want to do is keep calling the next 100 issues according to that query :).
Any help appreciated, I could do this through Python but would prefer to keep it instant on transition and within Jira :).
David Fischer
Actually, the limit of "searchIssues" is now 1000, not 100. However, you won't be able to create 1000 issues in a single Create Issue(s) post-function because you'll reach the execution time limit (5 minutes) of that post-function.
Ahmad Sidawi
Nice, the update to searchIssues addresses that first problem.
Is there any way to override that timeout? Or should we split the post function?
David Fischer
No, the timeout cannot be extended. The solution is to split the issue creation into multiple issues.
And you should be able to use the startAt parameter
