Hi everyone,
I'm struggling to find an automation that lets me sum up a numeric value of a custom field from epic to 'initiative' and higher.
Background:
What I did:
Problem:
The branch rule 'parent' is not working because it only works for sub-tasks (?). (It works if I put in 'linked issues' and manually create a relation between the epic and initiative. But this would require a lot of manual work for me)
Question:
Is there a branch rule or any other way that lets me sum a field value up the issue type hierarchy?
I do not believe there is anything built-in for that parent/child branching yet. There are several open suggestions for it that you may watch/vote for:
Until one of those is implemented, I wonder if you could use a branch on JQL to get at the parent. If you do test this with an advanced issue search does that return the parent issue, regardless of the hierarchy level?
Also, please consider:
