Jira Automation For Parent SubTasks Summary JQL
Samuel_Stinton April 8, 2024
I want to use Automation to set the status of a Task based on it's Sub-Tasks, I;ve got several sets of Subtasks all with a different prefix.
In the above while the "status != Done" is working and checks the Subtasks, The issue.summary is returning the contents of the Parent, what am I missing to pull the Subtask summary instead?
3 votes
Bill Sheboy
April 8, 2024
Hi @Samuel_Stinton -- Welcome to the Atlassian Community!
I do not believe you can use a JQL condition for your test.  The expression must be valid JQL, and you are performing a specific comparison for the first condition: comparing a substring of the summary to a defined string.
A work-around for this would be to use a smart value condition, an iterator over the subtasks, with conditional logic,  and a math expression.  For example:
  • first value:
{{#=}}0{{#issue.subtasks}}{{#if(and(equals(summary.left(3),"IT&"),not(equals(status.name,"Done"))))}}+1{{/}}{{/}}{{/}}
  • condition: greater than
  • second value: 0
How that expression works is:
  1. iterating over the subtasks in that parent issue
  2. use conditional logic to check the summary and status
  3. and when they match, add to the count
  4. wrapping all of that in a math expression, with a default value of 0 at the front.
Samuel_Stinton April 9, 2024
This is perfect, took me a while to get it filtered down properly and ended up transitioning from status X to Y once all subtasks for X were completed.
Thank you so much Bill!
Like Bill Sheboy likes this
Valerie Knapp
Hi @Samuel_Stinton , welcome to the Atlassian Community and thanks for your question.
Have you tried adjusting the branch for it to be, instead of For: Parent, to be for: Subtasks?
Please test this and share your results.
Cheers
Had a look with the hope of updating the Parent task on subtask closure and using that to trigger the Subtasks, but while this run successfully it doesn't match any subtasks to the IF and parent does not transition
John Funk
Hi Samuel - Welcome to the Atlassian Community!
Use {{triggerIssue.summary instead of issue.summary
Unfortunately I'm triggering from a Subtask on Transition, so the Triggerissue wouldn't check the other subtasks
