Jira Automation - How can I access issues from within a fix version?
Santhosh Dasika June 15, 2022
Hey All,
I am trying to use the jira automation to send an email every time a fix version is released. I want the email body to contain a table to all issues from the version, but I cannot see from the documentation that {{version}} has a property that can loop through the issues in the current version and spread out the properties in a table.
Is there anymore info I can read from and learn about this?
Santhosh
3 votes
Fabian Lim
Hi @Santhosh Dasika
Take a look at this tutorial where lookup issues is found. Link: https://community.atlassian.com/t5/Marketplace-Apps-Integrations/Jira-Automation-Video-Tutorial-on-how-to-send-customized-emails/ba-p/1861508
If you combine the version released trigger and the lookup issues with the send email action you may be able to achieve it.
Regards
thank you very much. this is great and has definitely helped me. Just a follow up question - if we have a property where the value is a list, how can we loop through those for the email?
i actually found the answer to this here - https://support.atlassian.com/cloud-automation/docs/examples-of-using-smart-values-with-lists/
Thank you very much again
Like # people like this
