I have a Task and I want to reuse the description with image from this task when a new subtask is created.
Copying the file and image is not working for me.
In you create issue action can you try to add the field attachment and copy the attachment from the trigger issue
I have another question. Do you know of a scenario where images would be copied from the description only? This way are copied from issue all attachments.
