Jira Automation Rule stopped running after few successful runs
Amulya Sankara March 17, 2025
I created a Jira Automation rule for a company-managed project which states that all issues with status NOT EQUAL to DONE should be moved to next sprint when the current sprint is closed. I had to add an automation rule for this since I have multiple statuses in the Done category.
This rule has been validated without errors but it did not execute when I closed the Sprint. I then created the same automation rule in a Test Project. And the rule executed successfully when I closed the sprint. I tried it a few times in the Test Project and it worked fine.
Today I executed this again and the rule did not work, even in the Test Project. In the Audit Log, it does not show that the rule was executed. I can only see the previous successful runs.
Has anyone faced this? And how can I troubleshoot this?
Thanks!
3 votes
Marc - Devoteam
March 17, 2025
Hi @Amulya Sankara
You rule mentions that the sprint has to be closed in a specific board.
Why don't set the trigger on sprint completed, without setting a board. the rule will then run on each sprint closed on any board.
When I select the condition of sprint completed, it is required to select the project board. It doesn't seem like this is a board related issue.
Like Marc - Devoteam likes this
Bill Sheboy
March 17, 2025
Hi @Amulya Sankara
When did you first notice this symptom of the rule not running?
There is an Atlassian production incident today where rules are delayed / not running when expected.  Please look here to follow progress on it:
https://jira-software.status.atlassian.com/
I did some tests and it does work sometimes and other times it gives me an error. Based on my analysis, it might be a timing issue and looks like sometimes the execution is delayed and so it doesn't find some steps in the rule during the delay.
I noticed it about 15 days ago for the first time. And investigated last week but it seemed to be working fine. I am facing the issue again today.
I am not sure if it's the Atlassian incident you shared, but this definitely seems like a likely cause.
Thanks for sharing! I will keep an eye on this.
Like Bill Sheboy likes this
Andrew Barnard
March 19, 2025
We have been experiencing this for the past week or so too.
We have rules to re-open jobs when a comment is added but the comment is being added, the job closed and then a few hours later it is getting re-opened like the automation has only just realised there was a comment.
Our rules are at Global level.
Vishal Biyani
March 17, 2025
@Amulya Sankara
Can you check if you are hitting the automation limits and hence the rule is not executing?
Automation service limits | Cloud automation Cloud | Atlassian Support
I have checked this and we have a lot of space left in the automation limits.
Vishal Biyani
March 17, 2025
@Amulya Sankara
Can you check and confirm if the scope of automation is project level or global?
It is in project level
