Hi Community!
I have 4 custom fields that are multi-select list. I need to be able to automate creation of a task (name of new task is based on custom field value selected), linking the newly create task to its "parent" and assigning the task.
My rule currently works only when a SINGLE VALUE is selected in one of my 4 custom fields. The rule also has over 65 components so I have to split it into multiple rules.. I want to make sure I am doing it the most optimal way.
USE CASE
We have a JWM project with a form for customers to submit an issue. That form has 4 custom fields that are multi-select list. There are a total of 27 values that can be selected from these 4 fields.
Based on the value(s) selected in the form for these 4 custom fields I need to:
RULE NOW
IF BLOCK
This is just the very first section as too long for print screen!
How do I write a rule that works when one or many values are selected in one of my 4 custom fields?
Thanks in advance!
Hi @Gail - So, it would help to have an understanding of the full context of the rule. This one can go down a rabbit hole really quick.
This will help in understanding how to proceed.
Thanks Mark.
The 4 custom fields are created to capture the type of work that a customer can request from this team. They wanted 4 vs 1 because they have 4 business areas. The fields are all multi-select list. We had thought about using components for this too, but that field can't be used on the JWM form.
To answer your #1 - These custom field values are "mapped" to a specific dev task name that goes into summary. EX: field value Design Activation - Social needs a new dev task created named Design: Social asset.
The fields are not specific to any issue to answer your #2.
Their ultimate goal was to have the customer complete the JWM form requesting work and have that form create an epic; however, this is not possible with JWM per Atlassian Support. They are OK with having the form create just a task.
That form created task represents their "project" so they need to create one development task and link that new dev task to the original form-created task.
The difficulty is that each potential custom field value a custom can select needs to have a set "linked dev task" name. We also have to put that set task name in the description as it is a required field.
I don't know if using variables is the route to take or what is best. As a callout - we don't have any Marketplace add-ons, and unfortunately we cannot install any so any scripting won't work.
Thanks in advance!
Thanks, can you please confirm my understanding?
If this is correct, you could do something like this:
{{issue.field1.value}}
{{issue.field2.value}}
{{issue.field3.value}}
{{issue.field4.value}}
This branches on each of the four fields. For each field, you're iterating through the selected value, creating a new issue, setting the summary to the current iteration and linking the newly created issue to the trigger issue.
sorry for the confusion -- this one is ugly.
On the form the user can select 1 or many values from one custom field OR all custom fields.
4 custom fields + their values: (( See below for screenshot of fields on our form ))
CUSTOM FIELD | Values | Task Names |
Marketing Content Development Support[Select List (multiple choices)] | Content Creation - Blog/Press release | Content: Blog/Press release |
Content Creation - Webinar | Content: Webinar | |
Content Creation - Content download | Content: Content download | |
Content Creation - Video | Content: Video | |
Enablement - External/internal resource | Content: Enablement resource | |
Marketing Design Support[Select List (multiple choices)] | Design Activation - Short doc | Design: Short doc |
Design Activation - Long doc | Design: Long doc | |
Design Activation - Illustration | Design: Illustration | |
Design Activation - Infographic | Design: Infographic | |
Design Activation - Ads/Paid media | Design: Ads/paid media | |
Design Activation - Social | Design: Social asset | |
Design Activation - Video | Design: Video asset | |
Design Activation - Website | Design: Website asset | |
Design Activation - Events | Design: Events asset | |
Design Activation - Printed materials | Design: Printed materials | |
Design Activation - Swag | Design: Swag | |
Design Planning - Creative concept/wrapper | Design: Creative concept/wrapper | |
Design Support - Canva | Design: Canva support | |
Marketing Ops Support[Select List (multiple choices)] | Mops Activation - Ads/Digital | Mops: Ads/Digital |
Mops Activation - Content download | Mops: Content download | |
Mops Activation - Direct mail | Mops: Direct mail | |
Mops Activation - Email(s) | Mops: Email asset | |
Mops Activation - Webpage | Mops: Webpage | |
Mops Activation - Webinar/Virtual event | Mops: Webinar | |
Mops Activation - List import | Mops: List import | |
Reporting - Analysis/QA | Mops: Reporting/QA | |
Marketing Social Support[Select List (multiple choices)] | Social Activation | Social: Activation |
_____________________________________________________________________
What I proposed should hopefully handle that. If they, say only select something for Field1, the other branches will quickly exit because there's nothing to iterate against.
Hi @Mark Segall hopefully last question.....
How does the advanced branching work with a custom field? I tried the code below, and it failed. Sorry -- I have never used variables and advanced branching before.
Can you please either copy/paste the error or share a screenshot of the rule log?
Can you try just using this for the smart value?
{{issue.customfield_10357}}
@Mark Segall now my next dilemma......
ACTIONS:
SPAWNED TASK NAMING:
In custom field 10357 - if user selects value
Is something like this even possible?
Your summary is static. If you want it to dynamic capture the current iteration of the field value, you'll need to use {{DS}} in your summary line.
that is exactly what I did in my last test. It is still generic BUT it is closer than the previous attempt. Thanks so much for all your help!!
Hi @Gail
Adding to Mark's answer...One easy way to add the extra, conditional text to your summary is with conditional logic. For example:
{{DS}} - some static text, as needed - {{#if(equals(DS, "Content Creation"))}}Blog/Press Release{{/}}{{#if(equals(DS, "Enablement"))}}Enablement Resource{{/}}
Just add this pattern to the end for each one you need:
{{#if(equals(DS, "value to check"))}}value to add in summary{{/}}
You would need to maintain this as your values change, but it is a quick solution to the need.
