Jira Automation To Create New Issue Based On Field Value - Suggestions?
Gail
Hi Community!
I have 4 custom fields that are multi-select list.    I need to be able to automate creation of a task (name of new task is based on custom field value selected), linking the newly create task to its "parent" and assigning the task.
My rule currently works only when a SINGLE VALUE is selected in one of my 4 custom fields.   The rule also has over 65 components so I have to split it into multiple rules..  I want to make sure I am doing it the most optimal way.
USE CASE
We have a JWM project with a form for customers to submit an issue.   That form has 4 custom fields that are multi-select list.   There are a total of 27 values that can be selected from these 4 fields.
Based on the value(s) selected in the form for these 4 custom fields I need to:
  • Create a new task (one task for each form value selected) with a specific name
  • Link that new task to the original form issue
  • Assign the new task to a person
RULE NOW
  • TRIGGER = when new issue is created
  • CONDITIONS
    • labels = business-form (JWM creates this when a form is used to create an issue)
IF BLOCK
  • CONDITION = JQL Condition (Example: "Marketing Content Development Support[Select List (multiple choices)]" = "Content Creation - Webinar")
  • ACTION = Create issue named "ABCD"
  • ACTION = Link newly created issue to original form issue
  • ACTION = Assign newly created issue.
This is just the very first section as too long for print screen!
How do I write a rule that works when one or many values are selected in one of my 4 custom fields?
Thanks in advance!
Mark Segall
Hi @Gail - So, it would help to have an understanding of the full context of the rule.  This one can go down a rabbit hole really quick.
  1. What is the rule doing besides spawning new rules that requires 60+ components or is that what it's come to as you've tried to capture every possible permutation?
  2. What are each of the 4 fields intended to do?
    1. Are all 4 fields contributing to the summary of the target issue (e.g. Summary is "Field1 Field2 Field3 Field4")?
      or
    2. Are each of the fields a source for separate issues (Issue 1 summary = Field1, Issue 2 summary = Field2, etc.)?
This will help in understanding how to proceed.
Gail
Thanks Mark.
The 4 custom fields are created to capture the type of work that a customer can request from this team.   They wanted 4 vs 1 because they have 4 business areas.  The fields are all multi-select list.   We had thought about using components for this too, but that field can't be used on the JWM form.
To answer your #1 - These custom field values are "mapped" to a specific dev task name that goes into summary.   EX:  field value Design Activation - Social needs a new dev task created named Design:  Social asset.
The fields are not specific to any issue to answer your #2.
Their ultimate goal was to have the customer complete the JWM form requesting work and have that form create an epic; however, this is not possible with JWM per Atlassian Support.    They are OK with having the form create just a task.
That form created task represents their "project" so they need to create one development task and link that new dev task to the original form-created task.
The difficulty is that each potential custom field value a custom can select needs to have a set "linked dev task" name.   We also have to put that set task name in the description as it is a required field.
I don't know if using variables is the route to take or what is best.    As a callout - we don't have any Marketplace add-ons, and unfortunately we cannot install any so any scripting won't work.
Thanks in advance!
Mark Segall
Thanks, can you please confirm my understanding?
  • Each field can have its own series of tasks
  • For every new form submitted, you will have anywhere from
    • 4 different tasks (user selected one value from each field)
      to
    • 27 different tasks (user selected every possible value)
If this is correct, you could do something like this:
  • TRIGGER: Issue created
  • BRANCH (Advanced) varField1
    • {{issue.field1.value}}
    • ACTION: Create Issue
      • Summary = {{varField1}}
      • Linked Issues YOURLINKTYPE - Trigger Issue
  • BRANCH (Advanced) varField2
    • {{issue.field2.value}}
      • Summary = {{varField2}}
  • BRANCH (Advanced) varField3
    • {{issue.field3.value}}
      • Summary = {{varField3}}
  • BRANCH (Advanced) varField4
    • {{issue.field4.value}}
      • Summary = {{varField4}}
This branches on each of the four fields.  For each field, you're iterating through the selected value, creating a new issue, setting the summary to the current iteration and linking the newly created issue to the trigger issue.
Gail
sorry for the confusion -- this one is ugly.
On the form the user can select 1 or many values from one custom field OR all custom fields.
4 custom fields + their values:  (( See below for screenshot of fields on our form ))
CUSTOM FIELDValuesTask Names
Marketing Content Development Support[Select List (multiple choices)]Content Creation - Blog/Press releaseContent: Blog/Press release
 Content Creation - WebinarContent: Webinar
 Content Creation - Content downloadContent: Content download
 Content Creation - VideoContent: Video
 Enablement - External/internal resourceContent: Enablement resource
Marketing Design Support[Select List (multiple choices)]Design Activation - Short docDesign: Short doc
 Design Activation - Long docDesign: Long doc
 Design Activation - IllustrationDesign: Illustration
 Design Activation - InfographicDesign: Infographic
 Design Activation - Ads/Paid mediaDesign: Ads/paid media
 Design Activation - SocialDesign: Social asset
 Design Activation - VideoDesign: Video asset
 Design Activation - WebsiteDesign: Website asset
 Design Activation - EventsDesign: Events asset
 Design Activation - Printed materialsDesign: Printed materials
 Design Activation - SwagDesign: Swag
 Design Planning - Creative concept/wrapperDesign: Creative concept/wrapper
 Design Support - CanvaDesign: Canva support
Marketing Ops Support[Select List (multiple choices)]Mops Activation - Ads/DigitalMops: Ads/Digital
 Mops Activation - Content downloadMops: Content download
 Mops Activation - Direct mailMops: Direct mail
 Mops Activation - Email(s)Mops: Email asset
 Mops Activation - WebpageMops: Webpage
 Mops Activation - Webinar/Virtual eventMops: Webinar
 Mops Activation - List importMops: List import
 Reporting - Analysis/QAMops: Reporting/QA
Marketing Social Support[Select List (multiple choices)]Social ActivationSocial: Activation
_____________________________________________________________________
Mark Segall
What I proposed should hopefully handle that. If they, say only select something for Field1, the other branches will quickly exit because there's nothing to iterate against.
Gail
I will give it a go.  Thanks!
Gail
Hi @Mark Segall hopefully last question.....
How does the advanced branching work with a custom field?    I tried the code below, and it failed.    Sorry -- I have never used variables and advanced branching before.
Mark Segall
Can you please either copy/paste the error or share a screenshot of the rule log?
Gail
The provided smart value was unable to be resolved to an object.
Mark Segall
Can you try just using this for the smart value?
{{issue.customfield_10357}}
Gail
same error - The provided smart value was unable to be resolved to an object.
Gail
I think it is {{customfield_10357.value}}
That worked.
Like Mark Segall likes this
Gail
@Mark Segall now my next dilemma......
ACTIONS:
  • used form to create new task - selected 2 values from the first custom field (10357)
  • In my create new issue action I could only give ONE summary.   I used This is the test - ds branching spawned issue" below.
    • I need each spawned task name to be different based on the values selected.
SPAWNED TASK NAMING:
In custom field 10357 - if user selects value
  • Content Creation - Blog/Press release then the task summary should be Content: Blog/Press release
  • Enablement - External/internal resource then the task summary should be Content: Enablement resource
Is something like this even possible?
Screen Shot 2022-10-26 at 9.42.28 AM.pngScreen Shot 2022-10-26 at 9.42.00 AM.png
Mark Segall
Your summary is static.  If you want it to dynamic capture the current iteration of the field value, you'll need to use {{DS}} in your summary line.
Gail
that is exactly what I did in my last test.   It is still generic BUT it is closer than the previous attempt.   Thanks so much for all your help!!
Bill Sheboy
October 26, 2022
Hi @Gail
Adding to Mark's answer...One easy way to add the extra, conditional text to your summary is with conditional logic.  For example:
{{DS}} - some static text, as needed - {{#if(equals(DS, "Content Creation"))}}Blog/Press Release{{/}}{{#if(equals(DS, "Enablement"))}}Enablement Resource{{/}}
Just add this pattern to the end for each one you need:
{{#if(equals(DS, "value to check"))}}value to add in summary{{/}}
You would need to maintain this as your values change, but it is a quick solution to the need.
Like # people like this
