Basicaly the title. Here is a screen shot of the automation i was attempting to do but I guess {{issue.subtask}} is not a thing.
you can access the subtask fields with {{triggerIssue.My Field}} smart value. You can see it on my test rule :
Let me know if this helps,
--Alexis
Thanks for the answer! it's exactly what I was looking for :D
Hi @Abdeladim EL AOUMARI , welcome on the community :).
One question... automation should be executed on subtask, when subtask is created?
Hi @Martin Bayer _MoroSystems_ s_r_o__
thanks for the welcome :)
Automation should be executed on the parent issue when a subtask is created.
{{triggerIssue.My Field}} suggested by @Alexis Robert worked for me.
