Jira Automation - trigger issue not showing in JQL branch
Rees, Ian
May 2, 2024
I am creating an automation, that has a manual trigger.  It looks at the fix version that the trigger issue is assigned to, then does a JQL branch based on "Fixversion= the fix version of the trigger issue
The problem I am having is that the logic in the JQL branch, never includes the trigger issue.  I have cut this down to a very simple script as follows
Bill Sheboy
May 2, 2024
Hi @Rees, Ian
My understanding is by default, automation rules with an issue in the trigger then remove that issue in any branching.  That is, the rule engine explicitly adds this to your JQL behind the scenes.  This is likely to prevent looping errors.
AND key != {{triggerIssue.key}}
One way to observe this is to intentionally add an error to dynamic JQL, and the broken JQL will show the addition in the audit log.
The workarounds for this depend upon your scenario...
  • If you want to count, sum, average, etc. a set of issues, use the Lookup Issues action with JQL, as that will not exclude the trigger issue
  • If you want to perform the same action on a group of issues, including the trigger issue, duplication is needed:
    • branch to the current issue, and perform the action
    • then branch to the remaining issues with JQL
  • Or...alter your trigger to not have an issue, such as with a scheduled trigger with no JQL
Rees, Ian
May 3, 2024
Thanks for the explanation Bill - that would make sense. Now I know it is intentional logic, I am working around by doing everything in the branch and then doing the trigger issue separately. Thanks
Like Bill Sheboy likes this
Rees, Ian
May 3, 2024
error
Kalyan Sattaluri
May 2, 2024
Hello @Rees, Ian
Can you share what are you trying to do?
For ex, You could also, instead of branch, do a lookupIssues before your branch, with same JQL and do an Advanced Branch on {{lookupIssues.key}} instead and act on your result set.
Rees, Ian
May 3, 2024
Thank you for the suggestion Kalyan but I am not counting, summing or averaging issues - I am creating a new fixversion which is a clone of another fix version i.e. the issues in it are also Clones. I think the answer is to do everything in the branch and do the trigger issue separately. Thanks
Kalyan Sattaluri
May 3, 2024
Great to hear.  Just FYI, you can do what you have mentioned in 1 step by Adv Branch on lookupIssues results also. Either way, many ways to do this and glad you got it sorted, Thanks!
