Jira Automation
Chamdarig Dall March 6, 2024
Please suggest how can I transition sub-task just after creation to the same status as parent issue. Eg. If task is in progress sub-task on create should be automatically moved to in progress
John Funk
Hi Chamdarig,
You can do that with an Automation for Jira rule (or ScriptRunner).
My question is how to do it using Jira Automation ;)
John Funk
Typically what is done is that the parent will move into In Progress when one of the Sub-tasks moves to In Progress. If the work is not actually being done and driven from the Sub-task, there is no reason to have sub-tasks.
But, what is the exact scenario that you want to happen and when?
Chamdarig Dall March 7, 2024
The exact scenario is to transition sub-task after creation to the same status as parent issue using Jira Automation
John Funk
SERVER
