Jira automation : Is it possible to change a drop down customfield ?
Grace Dehergne March 27, 2023
We have as set of drop down customfields and we wanted to set the values based on the value of a field.  Is it possiblle?
ex.
Customfield1 (Dropdown values -> Not Required / Required / Done)
Customfield2 (Dropdown values -> Not Required / Required / Done)
Customfield5 (Dropdown values -> Not Required / Required / Done)
Through automation : change all values to Required or not required depending on the value of the field :
To be deployed : Yes / No
Thanks in advance for your reply!
David Freitez
March 27, 2023
Hi @Grace Dehergne
Indeed it is possible, just use the Edit Issue component and select the Select field and set the value according to any IF/Else block you have.
In my screenshot, the Impact and Pending Reason are both select fields:
Hopefully this answers your question.
David
Grace Dehergne March 28, 2023
Oh thanks a lot @David Freitez ! I tried it in our Jira but the custom fields are not in the list,  I think  would have to contact our admin to expose the custom fields I need.
Jelena Tatomir September 24, 2023
It should be possible for the custom fields too using json in "More options".
See json documentation for editing issues.
