I'm not sure that my summary is descriptive enough, so here is my use case.
Issues are created in the project via an external form. Part of that form allows submitters to select a department and one or more countries. When multiple countries are selected, they are separated by a carriage return "\n".
The created task is then assigned based on the selected department and subtasks created for each selected country. Here's what my automation (triggered on issue create) does:
Note, steps 5-2 and 5-3 are two separate For each: Smart value loops.
So basically, if a user is assigned to a tasks department and one or more countries, they will only be assigned the original task and no subtasks will be generated. Users that aren't assigned to the department will get a subtask for each selected country for which they are responsible.
That all works great, but here is what I need to figure out:
Is it possible to create just one sub-task for each unique sub-task assignee instead of multiple?
For example, user1 is assigned to countries Spain, France and Italy. user 2 is assigned to UK, Canada. A task is created that isn't assigned to either one of them. Two subtasks should be created, The first one assigned to user 1 with the labels "Spain", "France" and "Italy", the second subtask assigned to user2 with the labels "UK" and "Canada". As of right now, my automation creates a subtask for each.
I can't think of a reliable method to do this because of the limited options inside the For each loop.
For your step 5.2 if the userID is the assignee of the task, then add the country as a label, to which issue are you adding the label:
If it is to the trigger issue, I suspect you could collapse the logic to one branch, always updating the trigger issue with either no change or use conditional logic in a JSON edit for the label.
If I have misunderstood your scenario, please let me know. Thanks!
Hi Bill,
In 5.2 I'm adding a label to the trigger issue instead of creating a subtask. That part is already working. The tough part is creating the subtasks so that there is a unique assignee for each subtasks with the associated labels.
I actually have a solution in mind but it will be a bit of a hassle to get it tested and working, but basically, I'll convert the <new line> separated countries found in the description to a comma-separated list
countryList = country1,country2,country3,country4
Then do a series of replacements, one for each country that iterates the list and pre-pends the assignee to each country or consolidates the country list under an existing user in the string eventually ending up with something like
countryList = user1|country1|country3,user2|country2,user3|country4
Then my For each loop will have all the information it needs (user and countries) to create the subtasks.
I have a start already using if() but still working through it. I just noticed that "|" is doing something strange, at least in the logs, so I may have to select an alternate secondary delimiter.
Thanks for that information, and...I'll admit I spent a long time trying to get your scenario to work yesterday before I deleted my long-ish post to ask that question instead :^)
I also decided a delimited variable would be better than the table for the country-to-user mapping and the branch should iterate at the user level, not the country level from the trigger issue.
That being noted, some tips to help you are:
Good luck!
Thanks @Bill Sheboy Sounds like we are arriving at roughly the same conclusion.
Can you flesh out an example of dynamic regular expression matching and inline iteration? I'm intrigued. :D
Certainly! A basic example would be this:
There are some extra steps if the search values could contain characters normally used in regular expressions, such as those found in date / time values. In that case, the values need to be escaped first using another variable.
Back to your scenario, how could this be used?
User1;(CountryA|CountryB)~~User2;(CountryC)~~User3;(CountryD|CountryE)
To ease maintenance, the user-to-country data could still be stored in lookup table in a people-friendly format, and then iterated to create the input to the advanced branch.
My preference is to store the Country to user in a lookup table {{countryMap}} so that the project admin can update as needed.
I have it all working but I'd like a more elegant solution if I can find one. Here's how it works:
Scrape the description for the list of countries and store in a comma delimited list {{countryList}} (adding an extra comma at the end)
{{issue.description.substringAfter("|*Countries*|").substringBefore("|").trim().split("\n").join(",")}},Then, this is the clunky part, I iterate over the list by creating a variable {{varC}} with a country like "Spain" or "Italy" and updating {{countryList}}
{{if(countryList.indexOf(varC.concat(",")).gte(0), if(equals(taskAssignee,countryMap.get(varC).trim()), countryList.replace(varC.concat(","),""), if(countryList.indexOf(countryMap.get(varC).trim().concat("&&")).gte(0), countryList.replace(varC.concat(","),"").replace(countryMap.get(varC).trim().concat("&&"), countryMap.get(varC).trim().concat("&&").concat(varC).concat("&&")), countryList.replace(varC.concat(","), countryMap.get(varC).trim().concat("&&").concat(varC).concat(",")))), countryList)}}That means I need two automation components for each country, one to set the country, one to apply it to the list.
To summarize the {{countryList}} iteration, it would look something like this
- If "country," is not found, return {{countryList}} unchanged
- Otherwise, if "country," is found:
- If the task assignee matches the country assignee, remove "country," from string
- Otherwise ,If the task assignee doesn't match then:
- If the country assignee is found in the string, then remove "country," and insert "country&&" after the found user ID + "$$"
- Otherwise, insert the user ID + "&&" before the countryThe result is that
Spain,Italy,France,Argentina,
becomes
useraaaa&&Spain%%Argentina,userbbbb&&Italy,userccc%%France,
Then the subtask creation is easy by splitting on commas and then splitting on "&&" inside the For Each loop.
Of course the requesting user has changed there mind about not creating a separate subtask for the the assignee of the main ticket so I'll have to make some adjustments. I also need to replace the country names with abbreviations to add to the subtask summary, but that is fairly easy with a long series of .replace("Italy","IT").replace("Argentina","AR") etc unless someone has a better idea. :)
Wow; I am glad to learn you found something that works!
Please consider...any approach that requires a lot of rule changes for updates to your user-to-country list could lead to errors. Be on the lookout for other approaches to solve this in the future.
