Jira automation - change status for issues created before a specific date
Dana.Harel
I want to use automation on all issues that were created before the following date-  31/12/2021.
If the issue status is open --> the automation will change the status to closed.
  • Trigger - I cant seem to find the correct trigger to start this automation.
  • Condition - seems like there is no option to set issues created before a specific date
  • Action - I've been planning to use the "transition issue" (would love to get new ideas as well)
Thanks!
Rilwan Ahmed
Hi @Dana.Harel ,
As you are trying to close all old tickets, I would suggest to make use of Bulk Edit and transition the required tickets to Closed status.
Please note: You should have permission to close on the listed tickets.
You can use JQL "created <= 2021-12-31 and status = Open" to find out the tickets.
John Funk
Agreed - if this is a one time action, you are better off doing a Bulk change.
Dana.Harel
Thanks! it's working
Like John Funk likes this
Rilwan Ahmed
@Dana.Harel ,
Glad it helped you. Please accept the answer. It could be helpful for other members with similar question.
