Jira automation, script runner, how to add value to new created worklog attribute?
kkoziol April 29, 2021
import com.onresolve.scriptrunner.runner.customisers.PluginModule
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
import com.tempoplugin.common.TempoDateTimeFormatter
import com.tempoplugin.core.datetime.api.TempoDate
import com.tempoplugin.worklog.v4.rest.InputWorklogsFactory
import com.tempoplugin.worklog.v4.rest.TimesheetWorklogBean
import com.tempoplugin.worklog.v4.services.WorklogService
@WithPlugin("is.origo.jira.tempo-plugin")
@PluginModule
WorklogService worklogService
@PluginModule
InputWorklogsFactory inputWorklogsFactory
def startDate = TempoDateTimeFormatter.formatTempoDate(TempoDate.now())
def worklogManager = ComponentAccessor.getWorklogManager()
def worklogs = worklogManager.getByIssue(issue)
// Add all fields needed to create a new worklog
def timesheetWorklogBean = new TimesheetWorklogBean.Builder()
.issueIdOrKey(issue.key)
.startDate(startDate)
.workerKey(currentUser.key)
.timeSpentSeconds(28800)
.build()
def inputWorklogs = inputWorklogsFactory.buildForCreate(timesheetWorklogBean)
worklogService.createTempoWorklogs(inputWorklogs)
This script is run in automation step. Got error: Work attribute 'Kategoria pracy'(_test1_) is required. This is work attribute in Jira Tempo
What to add to:
     .build()
To make it choose "Brak" in "Kategoria pracy"????
Prashant Mali
Hi @kkoziol ,
Is Work attribute 'Kategoria pracy'(_test1_)  is custom field?
You may help below code :-
import com.atlassian.jira.event.type.EventDispatchOption
def issueManafer = ComponentAccessor.getIssueManager()
def userManager = ComponentAccessor.getUserManager()
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def userToSet = userManager.getUserByKey("userkey")
def userCf = customFieldManager.getCustomFieldObjectByName("user picker") //custom field name
issue.setCustomFieldValue(userCf, userToSet)
issueManafer.updateIssue(user, issue, EventDispatchOption.DO_NOT_DISPATCH, false)
Hi, this is not custom field. It is work attribute in Jira Tempo
Prashant Mali
Hi @kkoziol ,
Oh! Its Jira Tempo plugin. I'm afraid this is not possible at the moment.
You check from below script runner snippet :-
https://library.adaptavist.com/collection/automate-daily-tempo-tasks-in-jira-with-scriptrunner
