Jira not sending Teams notification when issue created if the issue is created by automation.
Ksoon C January 4, 2024
I have set up two projects and created automation under each of them. Here is the information:
Project A automation:
When an issue is created, create an issue in Project B.
Project B automation:
When an issue is created, send notification to Teams webhook.
The issue I'm facing now is that if I create an issue manually in Project B, the "send notification" automation is working. However, if the issue in Project B is created by Project A's automation, the "send notification" automation will not trigger.
Any idea on how can i fix this?
Laurie Sciutti
Hi @Ksoon C and welcome to the Community!  Do you have this checked in your Project B automation rule?
Ksoon C January 5, 2024
Hi @Laurie Sciutti no, I didn't. I enabled it and retested; it's working now. Thank you so much for your help.
Like Laurie Sciutti likes this
Laurie Sciutti
@Ksoon C ~ excellent!  If you wouldn't mind accepting my answer, I would appreciate it!
