For context, I am trying to send a list of issues to Slack that have been in development for more than a week without a comment. The list of issues that have been in development for more than a week is quite easy, the comment part I am close but can't seem to finalize it.
I am attempting to use a logical statement within the lookup and can't seem to get the formatting right, currently what I have is:
{{#lookupIssues}}
{{#if({{comments.last.created.plusDays(7).compareTo(now)}})}}
YES #1
It complains:
First thing, try using a single slash to close expressions like iterators and logical conditions: {{/}}
Second, when inside of a conditional test, you do not need the extra curly brackets for the issue fields.
Next, I believe that compareTo() returns -1, 1, or 0: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-date-and-time/
Finally, to test in the conditional, I believe you need to use something like equals() test for this:
{{#lookupIssues}}
{{#if(equals(comments.last.created.plusDays(7).compareTo(now),1))}}
here is the key of a found item: {{key}}
Another idea: what do you mean by "in development" for this? It seems you are instead checking for things with the last comment date/time rather than, for example, in progress. Without seeing your entire rule and the JQL used for the Lookup Issues it is difficult to discern.
