Hello.
I've trying to understand how to link issues in JIRA, and I have found this linK:
https://confluence.atlassian.com/jiracoreserver073/linking-issues-861257339.html
But I am still trying to find a solution to my problem.
I have an epic, and this epic has 3 stories (story1, story2, story3).
I was able to link the 3 stories with this epic (I linked it: each story blocks the epic).
However, I wanted to be able to finish the epic, only if all the 3 stories are finished.
How can I do that?
This is, I want to link the 3 stories with the epic, so that it only be possible to finalize the epic after I finalize the 3 stories (in the workflow).
How can I acomplish this?
Hi @Fr0zt as @Alexey Matveev said you would have to have a plugin for this.
We are using Suite utility for jira plugin.
There you can define a workflow validator based on linked issues status exactly as you mentioned in your requirement.
Hope this helps :-)
I'm not sure anyone has bothered to write one, as it's quite simple to use. Install the app, then have a look through the docs for the functions you are interested in.
Docs are at https://confluence-apps.beecom.ch/display/JSU/Suite%20Utilities%20for%20JIRA
And the link validator only asks you three questions - https://confluence-apps.beecom.ch/display/JSU/Linked+Status+Validator
Ok. the thing is. I have installed Jira Suite utilities.
But where can I find the Validator? If I go to Jira Suite Utilities - configuration, I cannot find that. SO I am stuck in trying to find where to start using it.
Can you help me?
Validators are functions within the workflow, and as such, you edit a workflow and select the ones you want to use from the global list of validators available (then configure it for what you need within that workflow)
JSU adds validators to the global list.
I have installed JIRA Suite utilities for JIRA.
I've tried going into the setting -> issues -> Workflows.
I Select a workflow and select edit, and I am now in the process of editing it (adding status/transitions). But I cannot find anything for adding validators (as you can see in
the photo).
I have also tried to do this edit the workflow inside a project. but still without results. What am I doing wrong?
Click on the transition you need to validate, it will give you the properties and functions pop-up
Ok, thanks I managed to find it. My question is this: I have a task. And I created 2 subtask inside it (subtask 1 and subtask2). Task has workflow1. Subtasks have workflow2.
How can I make it, so that the task can only go to status done when both sub-tasks are also in status done?
3. Click Validators
4. Click Add Validators
5. Select the appropriate validator you want.
You would need an add-on for it like Power Scripts or ScriptRunner.
Thanks for your answers. What do you think is the easiest plugin to work with for that matteR?
It depends on your skills. I prefer Power Scripts.
