I have a scheduled automation task that runs every X days and then creates a task. I am able to link a single issue within this task. Great.
What i'd like to be able to do is to link all tickets generated using this automation so as to build up a history, or (preferable) use JQL to link them via say their Description.
At the moment I can only see a way to link one issue via the issue key.
Hi @Simon Evans - Can you please confirm my understanding of what you're trying to accomplish?
Is this correct?
If so, after your Create Issue action, you can add this:
Hi @Mark Segall thanks for the response.
This is what i want to achieve:
Currently i have this
Got it - So you'll want to do this after your issue is created:
