Hi Community, Just want to ask if I can make System Fields such as Priority to be a dynamic form.
I do have backup , which is literally scriptrunner , but I want to make it easier if its possible
Scenario is we have 4 Levels of Priority and the default value is Priority 4, when an agent is editing an issue in Edit Screen, if the agent change the value of Priority 4 to Priority 1 or Priority 2, related fields must be filled-up , if Priority 3 or 4 , nothing will be filled up
I have this script on my behavior as a backup but I think it is not working as what I've expect because it still requires me to fill up related fields even if the Priority is 3 or 4
import com.atlassian.jira.issue.CustomFieldManager
def samplefield = getFieldById("customfield_xxxxx")
def priority = getFieldByName("xxxxx")
if(priority.getValue()==("Priority 1") || ("Priority 2"))
samplefield.setRequired(true)
} else if(priority.getValue()==("Priority 3" || ("Priority 4") {
samplefield.setRequired(false) }
Can you help me guys out of this problem? Thank you!
you need to setup a validator on the workflow when create.
string errorMsg = "Mandatory"
if (priority== "3" || priority == "4") {
return false, relatedField, errorMsg;
https://confluence.cprime.io/display/TR/Validators#Validators-Validationbasedonregularexpression
Hi @Romy T. , I am referring to the edit screen, let's say if the issue is already created. Then the agent wants to Edit the Priority Field on Edit Screen, if the agents selects Priority 1 or 2 , related fields must come up
Hi @Alvin
you need to create two file.
main.sil
if(argv["screen"] == "edit"){
lfInstantHook({
"project",
"related-field","relatedField"
}, "/edit.sil");
lfWatch("priority", {"priority","relatedField"}, "/showRelatedField.sil", {"change"});
edit.sil
if(argv["priority"] == "1" || argv["priority"] == "2") {
lfShow("relatedField");
else{
lfHide("relatedField");
read this.
Hi @Romy T. , will take a look at this one, but I need to get Scriptrunner opinions first, because I already have scriptrunner installed. Thank you!
Fudeu fdo
i use Power Script for JIRA - Live Fields to control Dynamic Form.
Disclaimer:
just a user, not a seller.
Hi @Romy T. ,Thank you for a quick-turn around, can you show me examples on how you do it? or how about Scriptrunner?
