This should happen only for issues which are in approved state, and there are lot of issues whose due date is expired, i need all of them to move them from approved to open
Perhaps something like the rule below would help you:
However keep in mind that there should be a transition from all issue to Open (either create new transitions, or enable the global transition to Open)
Hi @sai chinamuthevi ,
If you have SLA enabled for your project then you can use the below automation rule.
