Need to Multiply 3 Custom field values in another Custom Field
Akshith Kumar March 23, 2022
Custom Field 1 - Impact
Not Applicable-0
Insignificant-1
Minor-2
Minor-3
Moderate-4
Moderate-5
Moderate-6
Major-7
Catastophic-8
Catastophic-9
Catastophic-10
Custom Field 2 - Likelihood
  • Not Applicable-0
  • Rare-1
  • Unlikely-2
  • Unlikely-3
  • Possible-4
  • Possible-5
  • Likely-6
  • Likely-7
  • Certain-8
  • Certain-9
  • Certain-10
Custom Field 3 - Counter Measures
  • Not Applicable-0
  • Best in Class-1
  • Strong-2
  • Strong-3
  • Average-4
  • Average-5
  • Average-6
  • Weak-7
  • Weak-8
  • Weak-9
  • None-10
    Custom field 4 - RPN
    So first three are single select list custom fields
    Custom Field 4 = Custom Field 1 * Custom Field 2 * Custom Field 3
    I.E RPN = Impact * Likelihood * Counter Measures
    Can someone help me to do this In Jira Data Center?
Tuncay Senturk _Snapbytes_
Hi @Akshith Kumar
As of my understanding, these are single-select custom fields and you need to convert them into numbers based on their values: e.g. Catastophic-8 is equal to "8", then multiply all three fields and set it to a number field which is customfield4.
Is that what you want?
Akshith Kumar March 24, 2022
Exactly
This might be a good starting point,
def customFieldManager = ComponentAccessor.customFieldManager
def cf1 = customFieldManager.getCustomFieldObject(id1) // id of the CF1
def cf2 = customFieldManager.getCustomFieldObject(id2) // id of the CF2
def cf3 = customFieldManager.getCustomFieldObject(id3) // id of the CF3
def cf4 = customFieldManager.getCustomFieldObject(id4) // id of the CF4 (multiplication result)
def cf1Value = issue.getCustomFieldValue(cf1).toString()
def cf1IntValue = cf1Value.substring(cf1Value.lastIndexOf("-") + 1, cf1Value.length()) as int
def cf2Value = issue.getCustomFieldValue(cf2).toString()
def cf2IntValue = cf2Value.substring(cf2Value.lastIndexOf("-") + 1, cf2Value.length()) as int
def cf3Value = issue.getCustomFieldValue(cf3).toString()
def cf3IntValue = cf2Value.substring(cf3Value.lastIndexOf("-") + 1, cf3Value.length()) as int
int cf4Value = cf1IntValue * cf2IntValue * cf3IntValue
issue.setCustomFieldValue(cf4,cf4Value)
there are some errors in the code can you look in to this and suggest changes?
You can't use space characters in your variable definition.
Simply change all "Counter MeasuresValue" to "CounterMeasuresValue" , etc..
but even our custom field has a space does it work if I write the code with out a space?
Yes, it will work. This is just the variable name, it does not need to be the same as the custom field name.
Like Akshith Kumar likes this
still there is an error in the last line
Can you please try this?
MutableIssue missue = (MutableIssue) issue
missue.setCustomFieldValue(RPN,RPNValue)
Don't forget to add this import statement to the top line
No errors now but it only displays null values with out any error in log
Have you checked the issue if it was updated?
Since your code does not return anything, it is normal to see null in the Result section.
Yes i tried creating new issues as well still no results
Is this post function? Where are you using this script?
By the way, you can add log.error lines to see whether your calculations are OK.
log.error("ImpactIntValue: $ImpactIntValue")
log.error("LikelihoodIntValue: $LikelihoodIntValue")
etc.
You will see the logs in the Logs section
i am using this script in script runner numeric field
Did you share a link?
Anyway, I think you are using a scripted field.
Then please skip the last line
instead, use this
return RPNValue
Thank you so much for your help Final It worked for me :D
@Ram Kumar Aravindakshan _Adaptavist_ Can you provide me the script based on this?
Nic Brough -Adaptavist-
March 23, 2022
What scripting/automation apps do you have available?
Script Runner,JEP,JSU automation Suite
