×Custom Field 1 - Impact
Not Applicable-0
Insignificant-1
Minor-2
Minor-3
Moderate-4
Moderate-5
Moderate-6
Major-7
Catastophic-8
Catastophic-9
Catastophic-10
Custom Field 2 - Likelihood
Custom Field 3 - Counter Measures
As of my understanding, these are single-select custom fields and you need to convert them into numbers based on their values: e.g. Catastophic-8 is equal to "8", then multiply all three fields and set it to a number field which is customfield4.
Is that what you want?
This might be a good starting point,
def customFieldManager = ComponentAccessor.customFieldManager
def cf1 = customFieldManager.getCustomFieldObject(id1) // id of the CF1
def cf2 = customFieldManager.getCustomFieldObject(id2) // id of the CF2
def cf3 = customFieldManager.getCustomFieldObject(id3) // id of the CF3
def cf4 = customFieldManager.getCustomFieldObject(id4) // id of the CF4 (multiplication result)
def cf1Value = issue.getCustomFieldValue(cf1).toString()
def cf1IntValue = cf1Value.substring(cf1Value.lastIndexOf("-") + 1, cf1Value.length()) as int
def cf2Value = issue.getCustomFieldValue(cf2).toString()
def cf2IntValue = cf2Value.substring(cf2Value.lastIndexOf("-") + 1, cf2Value.length()) as int
def cf3Value = issue.getCustomFieldValue(cf3).toString()
def cf3IntValue = cf2Value.substring(cf3Value.lastIndexOf("-") + 1, cf3Value.length()) as int
int cf4Value = cf1IntValue * cf2IntValue * cf3IntValue
issue.setCustomFieldValue(cf4,cf4Value)
there are some errors in the code can you look in to this and suggest changes?
You can't use space characters in your variable definition.
Simply change all "Counter MeasuresValue" to "CounterMeasuresValue" , etc..
but even our custom field has a space does it work if I write the code with out a space?
Yes, it will work. This is just the variable name, it does not need to be the same as the custom field name.
Can you please try this?
MutableIssue missue = (MutableIssue) issue
missue.setCustomFieldValue(RPN,RPNValue)
Don't forget to add this import statement to the top line
No errors now but it only displays null values with out any error in log
Have you checked the issue if it was updated?
Since your code does not return anything, it is normal to see null in the Result section.
Is this post function? Where are you using this script?
By the way, you can add log.error lines to see whether your calculations are OK.
log.error("ImpactIntValue: $ImpactIntValue")
log.error("LikelihoodIntValue: $LikelihoodIntValue")
etc.
You will see the logs in the Logs section
Did you share a link?
Anyway, I think you are using a scripted field.
Then please skip the last line
instead, use this
return RPNValue
What scripting/automation apps do you have available?
