None of our Groups have Product Administration permissions.
Tim.Bailey September 29, 2020
We are using JIRA Cloud with the new interface. About 60 users, about 30 groups, including the normal Admin Groups. When I review Properties --> User Management --> Groups NONE of the groups including all of the admin groups have 'Product Administration' permissions.
I am trying to add an App, and getting permissions denied responses. I believe the two are related.
How to I assign Product Administration permissions to a Group?
Do I need to find the first account that set up JIRA - is there some inherent super user access attached to this account.
Any help would be welcome.
John Funk
Hi Tim,
None of my groups have product access either, and I don't believe that is necessary.
What exactly are you trying to do and where is it failing?
I have just found a fix, so @John Funk please excuse me for hijacking my own thread.
To manage Apps (and some other stuff) you need the to be a member of the JIRA Systems Administrator group. This did not exist on my system.
Finally found a post that suggested that you just create a group with the correct name jira-system-administrator, add myself to it and also give the Group product access to JIRA.
Logged out and back in again for good luck and as if by magic I can administer a lot more of JIRA than I could before, including Apps.
So, if you do not have the correct groups present in JIRA Cloud, just create them using the correct magic words.
Like John Funk likes this
